Question about Irons
Product kry i have prod id 89578-022 -5000027 71389 +
  • 552 Answers
I need more information than this to fix it.
what is wrong, model name etc.
thanks
Posted on Feb 14, 2008
Need parts manual and wiring diagram
there are several sites and you really need to be more detailed on what product that you need a manual for. The bottom line is most of the time just go straight to the vender or manufacturer of the product. For example if you needed a manual on a 2015 ford Tarus you would go to www.ford.com. If you needed a manual on a Huffy Bicycle you would go to www.huffy.com. Good Luck.
other resources:
Product Manuals Retrieved
Free User Manuals and Owners Guides ManualsOnline com
User Manual Product Guide Download
May 29, 2015 | Irons
How do i register my purchase for warranty
Go to the manufacturers website and look for a link for product or warranty registration. The warranty on some products doesn't need to be registered. The receipt is the warranty. Other products have a warranty card in the box that needs to be completed and returned to the manufacturer.
Oct 30, 2011 | Irons
Iron does not heat up
try to open the terminal box of your flat iron use the ohmmeter test one prod on line one of service cord of plug to line one if you got a resistance or continuity it means line one of your cord is ok together with the line 2 test it possible your cord damage or try to test the heating element if has a resistance it means good or try to adjust the setting on rotate knob or fuse busted replace it.
Mar 07, 2011 | Oliso TG-1000 Iron
Calcium buildup - when ironing white specks keeps getting on clothes.
<span id="LblAnswers">.To solve this problem, switch to bottled spring water. Once the water is changed it will take several uses before your iron adjusts to the new mixture and the issue is corrected. </span><br>to speed that up Place the iron in clean or high stream mode if its a feature on your iron if not I would wipe it down with the solution usually 3 parts water 1 part vinegar.&nbsp; Also Rowenta sells a cleaner specifically for their irons&nbsp; and you can purchase it online here is the link its from macys but rowenta brand and is now on sale <br><br><a href="http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-%7Bkeyword%7D&amp;kw=%7Bkeyword%7D">http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-{keyword}&amp;kw={keyword}</a><br>
Aug 29, 2010 | Rowenta Irons
Dirty iron
Goo Gone...
http://www.drugstore.com/products/prod.asp?pid=81908&aid=336064&aparam=goo%20gone&scinit1=goo%20gone
I have used this to clean sparay foam off of floors and many other things...you may have to soak a paper towel with it and then lay it on and let it soften the stuff up...but give it time an it will work on anything...
heatman101
May 06, 2010 | Rowenta DX6700 Iron
User manual. how does it work?
Kindly click on this link to download the user manual.
http://www.retrevo.com/support/BlackAndDecker-C520-manual/id/20075dj388/t/2/
Should you have any questions, please feel free to post back.
Apr 11, 2010 | Black & Decker Gizmo C520 Iron
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
First time use instructions
You can download the manual from the link below: http://www.blackanddeckerappliances.com/dyn/prod/user-guide/104/D2000%20D2010%20D2020%20D2030.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 18, 2007 | Black & Decker D2030 Iron
Irons Logo
109 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
