Question about Kitchen Ranges
Oven heat control does'nt seem to work, not even on broil. The pilot is on the gas tube lights up barley then shuts off It's A GE XL44 mod.#JGB502 PN3WH SER.#RH109207P OVEN BURNER 1800-16.500
  • mec12202002 Feb 15, 2008
    What is the lighter?/location? Please.
    Is it the tube that lights up then shuts off
    after A few seconds?
    Sergeant:
    Champion:
  • 281 Answers
The lighter is dead
I suggest you to change it
Posted on Feb 14, 2008
Oven pilot light out on GE Xl44, how do i relite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101 ..
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have GE XL44 how do I lightthe oven pilot
    heatman101 .
    Jan 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Gas oven dosnt work
    the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
    Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven does not heat to proper temperature
    1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
    2. If the coils are ok, the problem may be with the thermocouple or control board.
    Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Spectra XL 44 Gas Oven Bottom Heating
    you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
    Apr 28, 2008 | Kitchen Ranges
    My GE XL44 doesn't heat up to full temperature.
    There are several things to check.
    1) check the broil element
    The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
    If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
    We rebuild these controls.
    Regards,
    Howard http://www.appliancetimers.com
    Apr 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Stove top pilot light
    I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
    Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 Range
    The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
    Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    214 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Marvin
    Marvin
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
