Question about Olympus FE-210 Digital Camera
Camera won't upload pictures.
When I plug my camera into the USB thingy, my camera doesn't do anything. If it's off, it doesn't turn on. If it's on, it just turns off. Sometimes it will beep with a flashing light, but that's it. The batteries are fine and the camera works perfectly. Except now, when I turn it off, the screen goes dark but on orange light is still on and the lens goes out and inm and then it turns off. HELP!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 07, 2012
ryanriopel28
  • 130 Answers
SOURCE: Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Posted on Aug 18, 2007
  • 11967 Answers
SOURCE: My Olympus FE-320 will not focus. When I turn the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 22, 2009
HarryHarley
  • 343 Answers
SOURCE: Olympus FE-330 won't turn on..... URGENT!
If it is a rechargeable battery, it may be bad. Start with that first. If your camera will accept standard AA batteries try those too. (just to test) Your 330 requires a LI42B or LI40B battery.
Check page 47 of your manual. Tells you about the battery. Your described problem sure points to a bad battery. Don't have the manual?? Download it here free.
Thats a nice camera you have.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1373
Posted on Dec 21, 2009
  • 11967 Answers
SOURCE: Camera will not turn on
Posted on Dec 31, 2009
  • 11967 Answers
SOURCE: Camera died while taking pictures. Lens is open.
Posted on May 04, 2010
My computer doesn't recognize my camera to upload my pictures. What can I do?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as PIcasa.
Jun 07, 2012 | FUJIFILM AX250 Digital Camera
When i connect the usb to the computer it just reads "connecting computer" but it doesn't do anything else. I don't know what to do to upload pictures?
Try NOT connecting your camera to your computer.
Aug 04, 2011 | Samsung L200 Digital Camera
When the cord is plugged in to connect to my camera's usb the lcd screen goes black and the computer does not recognize that anything is connected, so I cannot upload my pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 11, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
What usb cable do i need to recharge my camera and how do i upload photos onto my computer.
The DSC-W55 doesn't charge batteries via the USB port. It comes with a separate battery charger, which plugs into a wall outlet.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 11, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Uploading photos "camera Error"
May 26, 2010 | Kodak EasyShare LS755 Digital Camera
My M525 hp won,t upload
Jul 29, 2009 | HP Photosmart M525 Digital Camera
Won't upload pictures
May 10, 2009 | Kodak EasyShare C330 Digital Camera
Kodak md1063 cant upload pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jan 18, 2009 | Digital Blue EasyShare MD1063 Digital...
Not uploading to Mac with USB cable
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Sep 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
How do you upload a picture taken without a card on your Canon Rebel XT?
The rebel comes with a mini-USB adapter cable. Just plug it into your PC and the camera, and the PC should see it as a USB drive. Then copy or move the images as you would any other files. If you do not have the cable, they are available at Best Buy.
Jul 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Olympus FE-210 Digital Camera Logo
24 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
