Question about Linksys WRT300N Wireless Router
No internet through ports
I can configure wired router to get IP address, but I cannot see the internet through router. pc wired works fine through modem alone.
  • nswbbk Feb 16, 2008
    I think the router is fried. I cannot obtain a router ip or mac address, but i have a lan connection. wireless does not work either, first time I have trouble with linksys product wrt300n v1.1. even better I can't remeber when I purchased or where the receipt is. Going to spend more money!
    Guess what! I ran the linksys setup program and i'm back online, after it restored whatever was corrupted.
  • 55 Answers
Try hooking up the PC through the router, then unplugging the modem and plug it back in. Once that is up, do the same to the router and try it again.
Oftentimes if you're limited to one IP address, it will be assigned to your PC, and your router will be unable to get one. Resetting the modem frees the IP address and allows the router to get it.
Posted on Feb 14, 2008
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
Mar 12, 2010 | Encore ENHWI-G2 Router
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
If a change in my firewall is preventing netgear router, i do i fix?
First, make sure the cables are properly connected, if using xDSL modem, it must be connected to the WAN port, the pc on the ethernet ports (any of the 4 ports available).
Second, check your current IP Address (default 192.168.1.x), then ping from your pc the ip address of the router (default 192.168.1.1). If OK, then your LAN connection works fine.
Third, ping any internet site, i.e. ping www.yahoo.com. if a reply response is received, your internet connection is now working.
If not, reset the router then do the initial set up from the router web page. Go to IE or mozilla browser, type http://192.168.1.1 (default ip add of router), the password or username is admin (default - refer to your manual). If already inside the page, go to the setup folder then proceed to configure the router. After all the configuration, check your internet connection, go to any web site.
Sep 15, 2009 | NetGear WGR614 Wireless Router
Cant connect to internet
Configuring router for Cable Internet (LINKSYS)
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration Steps:
Step 1
Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for password and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection Type to 'Automatic Configuration (DHCP)' option. Under Setup, click on MAC Address Clone tab. Enable it and click on "Clone My PC's MAC". Do this from the computer which the cable modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router.
Step 4
Click on SAVE SETTINGS and then on REBOOT THE DEVICE including the cable modem to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.1. You can do this on your router under Setup > Basic Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Sep 02, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Can`t get wireless router to connect to pc. Have uninstalled/installed usb wireless adaptor no good. Router works fine on a wired connection on another pc nearby.`Wireless` pc 10m away from router has...
  1. Go to "Network Connection"
  2. Click Right "Wireless Network Connection" Go "Properties"
  3. Click at Internet Protocol(TCP/IP) and click "Properties"
  4. At General bar,. Click on Obtain an IP address automatically and Obtain DNS server address automatically and Alternate Configuration bars, click Automatic private IP address
  5. After all of this click "OK" and "Close"
  6. wait for 30 second and try to connect again
Nov 10, 2008 | Computers & Internet
D Link model 2310
When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
If it worked automatically, try this:
1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
3. Enter admin for the username and blank for the password
4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
5. Change the Router IP address to 192.168.2.1 then hit Save Settings
6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
Hope this works for you. Goodluck!
Nov 07, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless internet hookup
What seems to be the problem of your wireless internet?
Mar 27, 2008 | Computers & Internet
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
Linksys WRT300N Wireless Router Logo
112 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
