Question about Sharp LC-26D5U 26 in. HDTV LCD Television
DCR SET NOT RECEIVING ALL DIGITAL CHANNELS
SHARP AQUOS LC-26D5U DCR CAPABLE, CANNOT ACCESS CABLECARD MENU-GREYED OUT. ON INITIAL SETUP, DOES NOT ASK IF USING A CABLECARD, JUST ASKS IF YOU HAVE CABLE BOX HOOKED UP. I RECEIVE 2 STATIONS BUT CANNOT SCAN FOR AVAILABLE CHANNELS-GREYED OUT
  • 1 more comment
  • TREBUCK Feb 14, 2008
    I DONOT HAVE A CABLE BOX HOOKED UP, JUST THE CARD. MY SERVICE IS COMCAST DIGITAL CABLE. HAVE AN ANALOG TV WITH CABLE BOX HOOKED UP TO SAME SERICE- NO PROBLEMS.
    GUY WAS OUT HERE AND HE COULDN'T FIGURE IT OUT. WILL ASK THEM AGAIN. THANKS
    BEAT YOU TO IT. LOOKED IT OVER SEVERAL TIMES. TRYING TO GET IN TOUCH WITH SHARP WITH NO LUCK. THAT'S WHY I CAME TO THIS SITE. THANKS SO MUCH.
    Genius:
  • 3,422 Answers
Click HERE to view the user manual.Go through it carefully and i am sure you will find a solution to your problem.
Goodluck..
Posted on Feb 14, 2008
    Brigadier General:
  • 3,614 Answers
It has to be re-program your tv set. maybe you can call your cable provider for assistance to program your channel.
  • micromaster
    micromaster Feb 15, 2008
    I really appreciate for your kind compliments to me (trebuck).
    And nice to hear that i help you in simple way.
    Regards,
    micro
    Guru:
  • 1,894 Answers
Hello sir
  • 1 more comment
  • dewan nafees ahmed Feb 14, 2008
    ok here you go.
    this is not a big problem sir.
    the reasons for problem are are as follows.
    1>> when you receive two channels then the problem is the SHARP is not able to detect the signals from the cable box which you are using.
    for this you ask your provider of the BOX if the BOX is compatible with the TV model you are using. weather your TV can detect the signals of all ranges from your box.
    2>> if compatible then you can make sure with the different card
    .. it ca be the problem with your card also.
    3>> now even this is not working you wil have to ask your provider to replace the box which you have been given with a new and latest box.
    follow all these steps..
    this will fix you hope fully..
    thanks a lot...
    wish you good luck ..
    thank you
    NOTE:
    dont forget to accept my solution..
    thank you very much..
    wish you good luck
    also have this manual to check with the compatibility..
    this is link for manual
    wish you good luck
How do I get the tv to scan for channels
For the LC-xxLE Aquos models the channels can be setup using the Menu button and going to the Initial Setup -> EZ Setup screen. Choose the home and air/cable options and start the channel search. If you have a working antenna or cable input, the TV will discover all the working channels.
Feb 01, 2016 | Sharp Aquos Televison & Video
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
Aug 26, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
Nov 22, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Sharp LC-26D5U 26 in. HDTV LCD Television Logo
172 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
