Question about HP DeskJet 990cxi InkJet Printer
Always prints green
i am hoping you can help me. I have new ink cartridges (colour and black) - every time we print something it always comes out green. I have no idea how to fix this problem. When the new cartridges were installed and test paper printed and all colours came out on the sheet. I have a college student and a junior high school student in my home so getting this fixed will stop the whining and complaining, if you know what I mean, lol.
  • 286 Answers
Try using the CD that came with the printer to uninstall and then reinstall the printer driver.
Try a test print. Go to Start/settings/printers and faxes.
Right click on the driver and select properties. Click on the test print button.
Did the test print correctly?
Posted on Feb 14, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
The colours on our HL-4040CN have gone all strange - when we perform colour calibration the colours go either red or green. All toners are new and the drum has been replaced recently as well. We do a lot...
Hi
We need to isolated the problem on what cause ink cartridge not print in color. When even you installed new cartridges, It is necessary to run the print nozzle to clean the print head. Also, please try to clean the print head manually by removing all the ink cartridges and rub the print head into a white paper with alcohol until ink flows and then return it back and run the print nozzle for 2 times.
Then try to print again.
If it does not help you, please let me know to give you more help.
Mar 03, 2011 | Brother HL-4040CN Laser Printer
Hi, I have a Canon Pixma MP560, and whenever I try and print something in black and white it comes out with a pink tint to it. Hope you can help.
Possible that the Ink cartridge or the head is faulty. Ink drying can make this imbalance of colours , so check to correct with the properties of the printer, If not clean several times to see any changes come about with a test print.
The last can be the ink/head unit.
Sep 20, 2010 | Canon Office Equipment & Supplies
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
Color ink is not working
Dear Black Rose
It is strongly recommended to change your colour cartridge.
Or it can be possible that you did not use your colour cartridge for a long time.
The nozzle of colour cartridge are blocked, if you did not use your colour cartridge for a long time.
Purchase a new cartridge if you can or go for a local refiller to refill (if possible) your colour cartridge.
Thanks
May 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP 6110 All in one
Various models do different things so you will have to checkout some stuff. 1. black is green- what it mean is if you take some black ink and wet it to dilute it will sh0w dark green then lighter etc., because black is all colours mixed. In most printers when a 'black' document is printed actually all colours are printing - take a look under a magnifying glass. Some printers however allow for 'black' only printing. But you have to set it up. So check your manual and software or what comes up on the screen. Then come come back
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet 990cxi InkJet Printer Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
