Question about Belkin (F5D6230-3) Wireless Router
Can't access my computer onthe internet
Hi
I have registered my ip address of the computer with no-ip.com but i still cannot seem to connect to my computer from a different location on the internet. I have created a virtual server with the LAN ip address and the port number to 80, but is till seem to fail to connect. Please can someone advise.
Many thanks
  • Ustadf Mar 07, 2009
    dante777,
    Apologies for taking too long to respond,
    Unfortunately I still don't have the result, howvever I will let you know as soon as i can. Currently I am facing problem getting my computer loading up. I have done few tests and waiting for few RAMs to be replaced.
    I will let you know of your suggestions ASAP. For meanwhile just to answer some of your questions;
    1. Make sure that your ISP is not blocking port 80. You can check that here. (Otherwise switch to another port like 8080 or 805) - Well need to come back to this.
    2. Have you setup your DDNS service on your router or ensured by other means that no-ip has your up-to-date external IP? (Make sure that your external IP matches the entry at no-ip.com!) - Checked - OK
    3. Set your LAN server to a static IP address - Is this not dependant on the ISP (usually you have to pay extra for static IP) ?
    4. Make sure that port forwarding is enabled and pointing to your server.
      - That means: if you run a webserver on port 80, you have to set the external port to 80 and leave the internal blank, unless your internal server listens on a different port. - Checked OK
    If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? - Not helpful, but If i remember I think it is a 404 error
    kind Regards
    President:
  • 623 Answers
If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? Please provide details.
I think this might be interesting for some other people too. So please come back and leave a comment!
Posted on Dec 29, 2008
  •  C. Dante
    C. Dante Mar 09, 2009
    Hi Ustadf,
    just to come back to some of your comments:
    LAN IP means that you do not let your router assign an IP address for that machine via DHCP, but rather give it a dedicated Ip address. The reason is that you port forwarding from the router has to point to a dedicated address, otherwise the request for port 80 runs into nowhere. Look at the screen shot and you should see what I mean:
    If you need help how to do this - let me know and I'm happy to assist you (or look here for a good description.
    A 404 error is returned when the requested web page cannot be found. Either there's someting wrong with your page (index.html is not in the primary directory) or your router can't direct the request to the right machine (see above).
    Can you get to your webpage from your internal network (LAN)?
    Good luck on the RAM and let me know how things are going!
When my wireless access point is turned on, my computer is unable to renew the ip address. I show excellend signal strength, but "little or no connectivity"
Hi, Your computer is most like have IP address permanently asign. To change the setting for windows 7, click start, click control panel, click network & internet, click network sharing, click connection, click lower left hand property, click Internet protocol version 4 (TCP?IPv4), click property and click obtain and IP address automatically. Your Router will asign IP address. Windows XP, Click start, click connect to, click to show all connection, right click to the wireless connection adapter, click the property and click the down arrow click to TCP/IP, click the property and change it to obtain IP address automatically. That should work for you. Get back to us if this information help you solve you solve the problem. Good day now.
Jul 13, 2011 | NetGear WG602 802.11g/b Wireless Access...
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
My dsl internet light stays red when plugged into the router, but okay when plugged into my computer
print2.gif print email2.gif email
Title: Setting up Cable Internet for the RV082 Article ID: 16585
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is assigned a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Step 1:
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb16585_001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Step 2:
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
Step 3:
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports.
Step 4:
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
Step 5:
Access the router's web-based setup page. For instructions, click here.
Step 6:
Go to the Setup - Network, click the drop-down arrow under the WAN Connection Type field and select Obtain an IP automatically for WAN1.
kb16585_002_en.png NOTE : If you are going to have another Cable Internet as well in WAN2, select obtain an IP automatically as well.
Step 7:
Click Save Settings.
Step 8:
Check in the System Summary if the router is getting a WAN1 IP or WAN2 IP.
NOTE:
If there are no IP addresses seen in this field, go back to Setup then click the More option to reveal the MAC Clone settings.
Step 9:
Select MAC Address from this PC.
Step 10:
Click Save Settings Button.
Step 11:
Click System Summary. Check the value of the WAN1 or WAN2. If these have numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem.
kb16585_007_en.png NOTE: If the WAN1 IP or WAN2 IP is all zeroes (0.0.0.0) click first Release then click Renew buttons. If the WAN1 IP or WAN2 IP is still all zeroes (0.0.0.0) perform a power cycle.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment.
Step 12:
Once the router is configured, perform a power cycle. Shutdown the computer and Unplug the router's power cable. Unplug the Broadband modem's power cable and wait for 30 seconds then plug in the Broadband modem's power cable and wait for its lights to appear stable. Plug in the router's power cable once the modem's lights appear stable.
Step 13:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router. For instructions, click here .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 25, 2010 | Linksys RV042 VPN Router
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Wifi connection problem
plz try to configure ur manual ip addressing on ur laptop .Hope u will access internet soon ....>>>>becuz its prb with ip address
May 12, 2010 | NetGear DG834G Router
Cannot acess ip address
HI! you can access the ip address of your router by connecting it directly to your computer.. if you are using a windows xp operating system. use your mouse and click on start and select run, from there it will show a box and type in on the box cmd and it will show you a dos prompt and from there just type ipconfig /all and it will show your ip address..
Jul 19, 2009 | Computers & Internet
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
Hpg6000 Vista 32 cannot access via browser
Hi.
This problem usually occurs if DNS addresses are not set-up correctly.
DNS addresses are IP addresses of DNS servers which translates your queries to IP addresses. Like, when you enter www.google.com in your browser, computer sends this to DNS server, then DNS server gives back information of the address of the site you're trying to visit. Since your computer does not know where DNS server is, it cannot display your web page. Some programs like Messenger and Skype work by quering exact addresses (since they are made to connect to single database on Internet), and that's the reason they are connected to Internet.
  1. Ask your Internet provider for DNS addresses.
  2. Open Start menu and then Control Panel.
  3. Open Network Connections.
  4. Right-click the connection you are using to connect to Internet, and click Properties.
  5. From the item list, choose Internet Protocol (TCP/IP).
  6. Click Properties.
  7. Click Use the following DNS server addresses.
  8. Enter given addresses.
  9. Click OK and then Close.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 21, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Limit or no conectivity problem
I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
If you don't have a router to share the connection then you are using Windows ICS connection.
When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of 192.168.0.1.
You can check this site for more information
http://www.annoyances.org/exec/show/ics_xp
You can try to connect the two computers first without the internet connection.
Example : PC A 192.168.0.2
You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
And for PC B 192.168.0.3
You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
To start the wizard
1.
Choose Control Panel from the Start menu.
2.
Click Network and Internet Connections, and then click Set up or change your home or small office network.
http://www.smallbusinesscomputing.com/webmaster/article.php/3293481
http://www.homenethelp.com/connection-sharing.asp
http://practicallynetworked.com/sharing/xp_ics/
Mar 05, 2008 | Computers & Internet
Belkin (F5D6230-3) Wireless Router Logo
254 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
