Question about Maytag MDG6400 Atlantis Gas Dryer
Maytag washer I have a maytag washer MAV7057AWQ, I am trying to find the capacity but can't. Also it spins but has never been well balanced, it shakes a lot and now it won't spin out very well. We have to spin it at least 2 times. What would make it do that?
5 Suggested Answers
  • 20 Answers
SOURCE: Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Posted on Jan 19, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: load off balance error dc. Wont rinse or spin
Hello nikimiguel,
I’m an Owner like you I own the FAV6800AW and have helped many folks on this and other forums with this issue.
You are experiencing a classic malfunction of the One-Way Roller clutch bearings in the Clutch Pulley assembly. It sounds like you are in the early stages of the issue. I have put together a step by step maintenance process to clean up and re-lube the One-Way Roller clutches in the Clutch Pulley assembly see this post Clutch Fix Post for what’s involved. Look on the right top back of your Console. If you can give me the first two numbers of your serial number i.e. 10, 11,12, tru 17. That will let me know if your machine will use an Upper One-Way Roller clutch bearing ring. Mechanical skill sets to perform Clutch maintenance or replacement are basic, anyone can do this it’s just a tight work area. Your option is to DIY or call in a repair service. I would ballpark the repair cost at around $300 if they know what is wrong and how to fix. DIY the fix it and you may need a a can of WD-40 and Slick 59 One Lube cost around $10 if the One-Way Roller just need to be cleaned up and re-lubed. If the Clutch pulley needs to be replaced I will show you a site where you can purchase for around $60 delivered to the house.
See this most recent post of a forum member who is back in service with my process.
Standing by if I can help….Rich aka dh1200s
Posted on Dec 14, 2009
SOURCE: Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Posted on Feb 16, 2010
  • 569 Answers
SOURCE: i have a brand new maytag 4000 series front loader
This sounds like the transportation support rods have not been removed. A new machine will have two or more steel rods supporting the drum to prevent damage during transportation. These rods MUST be removed before the machine is used, otherwise the dampers that prevent excessive vibration will not be effective.
The user manual should provide instruictions for removal of the rods. They are normally accessed from the rear of the machine and usually will be labelled so that it is clear how to remove them. They pass througn the chassis of the machine and should be unscrewd and pulled out from the rear.
Posted on Jan 22, 2011
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Feb 15, 2010 | Maytag Performa PAV2200
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
MAYTAG MAH5500B SHAKES DURING SPIN IMMENSELY, IS ON
that sounds like your tub bearing is out. open the door reach in grab the metal tub and try to push it back -n- to th front. if you hear a thump or a lot of movement its the bearing. i have replaced them before and they ****!! it takes a good repairman two hours to do one and it an expencive endevour
Oct 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG WASHER - TOP LOAD MODEL #HAV2360AWW
You need to replace the wax ring. Mine did the same thing. My washer was new and still on warranty. I had them replace the ring and it was good for awhile and then it started again. So I called Maytag again and they got me a new washer. I don't have that problem anymore unless I do a lot of towels and it gets of balance. Hope this helps.
Aug 13, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
