Speakers not working
I cannot get the rear and ceter speakers to work.The amplifier is an older unit and it has dolby prologic. mod no. A- SV 210 MADE JUNE 1996 I have never tried to hook up all speakers before and I bought it new.
  • buggyman Feb 15, 2008
    thanks will try
    thanks will try
  • 44 Answers
Also take a good look at the back of the amplifier. Some have jumpers that might need to be moved.
Check out the other speakers by temporarily connecting them to the outputs that work to make sure the extra speakers are ok.
Posted on Feb 14, 2008
  • 35 Answers
Make sure that you have switched on/pressed all the needed button to have the center and the rear speaker to work. there is a switch there that allows you to choose either stereo ( left and right speakers only ) or surround ( center and rear speakers included ).
A Simple Thanks is Good Enough
Rear speakers only work during calibration and testing. Not during playback.
This commonly happens based on the source. For example, if your receiver looks at the source that is analog, it will use two channels, the two front left and right speakers. However, some receivers, such as a Denon, have a 5 channel stereo feature that will utilize all 5 speakers (L&R Front, Center, L&R Rear). If you are connecting a DVD player, often you need to configure the source appropriately. If you are connecting using the RCA cables, it will be stereo. If you are using Optical or Coaxial connection, you can enjoy Dolby Digital, but may need to specify in the receivers setup to use these audio source inputs. If you are connecting via HDMI, early versions only supported Dolby Prologic, but you occasionally hear mono sound from rear speakers. Without knowing more about your equipment, what source you are hoping to hear and how you are connected, it will be difficult to pinpoint your cause, but hopefully this helps your understanding to enable you look for the appropriate cause.
Oct 06, 2014 | Audio Players & Recorders
Sound only coming from 3 of 6 speakers
A 5.1 sound card will give output in all channels only if the audio being played is also 5.1.
Normally out of 6 Speakers only 2 front and sub woofer will play sound, in case of a DVD or Movie which has 5.1 encoding, all 5 will come alive.
Also, Dolby Prologic II and Dolby Digital will convert a 2 channel input into psudo 5.1 enviornment but Dolby has to be in hardware or speakers or Receiver.
Jan 21, 2014 | Creative Labs MegaWorks THX 550 Computer...
If is hooked up to the system properly. I
check the setup menu if your unit has one. verify the output and the input audio options are set to the correct types. verify that your output is setup to allow for dolby, prologic or surround.
Mar 29, 2010 | Audio Players & Recorders
Our new lg 5.1 surround sound system will only play full surround sound on some new release blu ray films and the rest will only play through the front 3 speakers as dolby stops as soon as you get past the...
Dolby will only activate when it has information for all 5 channels. For normal stereo only left, right and bass boost speakers work, so you lose center and rear speakers. The system should have an option to play SIMULATED surround sound, to activate all speakers. In many systems, this option is called dolby prologic, simulated or some other fancy name.
Jan 17, 2010 | Audio Players & Recorders
Need help hooking up surround sound with my Sherwood DAS
Sherwood's site has a manual for the model RV-4060 (click here to download) but not for the 4050. You might find it similar enough to help you. Otherwise you can try a Google search for generic Dolby surround connections. It's usually pretty straightforward. Connect the audio out from your source (TV, DVD player, etc.) to the receiver. Connect the surround channel speakers to the appropriate rear panel jacks. Fire up a source you know has Dolby encoding, turn on receiver's Dolby processing from the front panel, and experiment with the different modes to hear what you get. Just remember you can't break anything just by pressing buttons.
Jun 02, 2009 | Televison & Video
Speakers won't connect
Here is a link to Samsung's HT-Z510 Home Theater rear speaker troubleshooting guide.
http://www.samsung.com/us/support/popup/howToGuidePopup.do?howto_guide_seq=629&type=hometheater&subtype=hometheatersystems
It has worked for me after a couple tries. Good Luck!
Dec 27, 2008 | Samsung SWA-4000
Help for AVR - 688
check the following1-no headphone jack is inserted.
2-check power cord firmly connected.3-if you have any doubt in remote change the battery with fresh new one4-unplug the system from power and replug it.5-check your volume level maybe it is in low level.-setup your speaker again.6-check speaker cables disconnection-7 -check that mute button not pressed.
Jul 12, 2008 | Denon Audio Players & Recorders
Playstation 3
First of all, Linear PCM is the best option to choose. PCM (Pulse Code Modulation) is a format for uncompressed raw audio data.
Some 5.1 sets have Dolby ProLogic II for example. The raw PCM output gets spread at your speakers dynamically. Meaning the decoder of your set interprets it the way it thinks is best. For example, if it gets a high frequency tone, it sends it to the center speakers as for human voice has a very high frequency. The center speaker is meant for dialogs.
But when you choose a compressed, encoded format such as Dolby or DTS the channel devidance is already mixed for you for optimal theatre experience.
When you choose DTS or Dolby in the menu of your Blu-ray Disc it will originally output a raw PCM audio stream. The decoder knows how to decode the DTS data out of it when you use the DTS audio track from the movie. The same goes for Dolby. Some movies can output pure PCM, but then most sets use ProLogic II to devide it over the speakers.
It's kinda hard to explain how it works, bottom line is.. there's nothing wrong.
I hope it makes sense to you and your question is answered.
Greetings,
DarkNeogen.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
54 people viewed this question
 Grubhead
Grubhead
