Question about Logitech Z-5300e Surround Sound System Computer Speakers
Z-5300 blown fuse
Fuse blew during light use. Have tried new 125v 2amp slo-blo. Keeps blowing them, even with no imput or out connedtions hooked up.
  • therick0145 May 11, 2010
    how much would it cost to have this looked at, you think?
    im having the same issue, and its out of warranty, so they wont send me a new system.
    it repeatedly blows a fuse the instant any power goes to it.
    i did not abuse it in any way... wtf...
    Champion:
  • 206 Answers
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Posted on Feb 14, 2008
I need to find a fuse for my jbl sub 160 subwoofer.
Those are pretty common. I'd pull the old one just to make sure the new one looks like it and be SURE the new one is a "Type T" or Slo-Blo.
Google "30mm 3.15A 250v slo blo fuse" and you will find them at Mouser, DigiKey, even Amazon. Better still--if you have a local electronic parts store, go there.
Sep 28, 2015 | JBL Audio Players & Recorders
Hammond organ c2 hook to a 147 leslie speaker it keep blow the 1.5 slo blo fuse how do I fix this
Like all the past answers, make sure everything is clean and lubricated expecially on the Lesley if it's a motorized rotating speaker, the slow blow fuse is telling you there is a problem ?
Feb 22, 2015 | Music
Peavey Vyper Tube 120 keeps blowing fuse
You are either trying to: (A) push it too hard, (B) using the wrong type of fuse -- should be a "Slo-Blo" type, or (C) it has internal shorting or voltage modulation and requires service.
Jan 11, 2013 | Music
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
The small ceramic fuse inside the monitor has blown. Where can I geta replacement, and what is its value. It is difficukt to read whether it is 3.15amp or 15am?
wvc12, You will need to look with magnifing glass. could be ".315a or 3.15a" Check with Newark for proper rating( fast-blo or slo-blo) . LittleFuse makes both types. Will also need to know first 2 or 3 letters in front of amperage. Also check "DIGIKEY.com" You will also need to determine if fuse blew from "old age" and just got "tired" or did it blow because some other active (solid state) or passive device has failed!!! Good luck with this one. 12fixlouie
Oct 18, 2010 | LG Flatron L1800P 18.1" LCD Monitor
Definitive Pro-Sub 1000 subwoofer replacement fuse.
Fit a 3 or 2.5 anything lower, if you can get away with it, but nothing higher.
However the chances are that it blew due to an overload, often caused by a shorted semi-conductor acting like it was a piece of wire. So even fitting a smaller one and it blowing again doesn't mean it's due to the rating.
Jun 25, 2010 | Definitive ProSub 1000 Subwoofer Speaker
The lights do not go on at all, it does not turn on
It may be the power supply fuse. The fuse is a "2amp Type T or slo-blo 250v" if you live in north america. If your electrical current is 230v like in europe the fuse you need is "1.25amp Type T or slo blo 250v". You will need to unplug the unit from the wall outlet, unplug all cables, and set the unit on a padded surface. Remove the 10 screws holding the amplifier to the sub box and remove the amp assembly from the box. At the bottom of the circuit board is a glass fuse, gently remove that fuse and inspect it for obvious signs, like dark burn spots. If you can, check it for continuity, or just replace it. Also before going through this check the outlet that the sub is plugged into for power.
May 16, 2010 | JBL PB10 Subwoofer
All of a sudden, no power, no lights, NOTHING!
if the microwave is on the same circuit as the refrigerator, it's possible that the micro was turned on just as the refer compressor kicked on. i've seen that situation pop a fuse in microwaves many times - make sure you get a ceramic slo-blo fuse
Aug 22, 2009 | Emerson Black Microwave Oven
Logitech Z-5300e Surround Sound System Computer Speakers Logo
429 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
