Question about E-Machines eMachines Desktop PC
Sounds disorted and skipping
When running a certain program the sounds come out all funny and skippy i tried putting in a new cd driver and that is not the problem, audio cd plays fine now.
  • E-Machines Master
  • 19,396 Answers
Check that you are using the correct audio drivers for your PC. Eventually you can buy a PCI sound card, which is quite inexpensive, and install it on the motherboard. It can replace the sound card integrated with the motherboard. once the new card is installed the old card must be set on ' do not use this device (disable)' from device manager.
Posted on Feb 14, 2008
DVD CD audio is garbled and sounds "skippy" o garbled
DvD playback can be a result of dirty lens on your dvd player and bad driver updates from your dvd program vendor. if this is the problem try to check back when you think it started and see if you had any driver updates or software update. use a good dvd cleaner and then check the results.
You can look in the event veiw. Go to my computer right click and than click manage you will see the event viewer and it will show you any conflicks that have happen. if it is a driver conflick remove the driver and it should fix your problem.
Mar 20, 2009 | Dell Inspiron 1525 Notebook
Distorted / skipping sounds from Acer laptop
Go to the sound icon which is at the right hand bottom corner on your task bar, explore properties cheack wheather voice supression is any thing else than 0.As well as check for enviroment.
Mar 14, 2009 | Acer Aspire 5100 Notebook
CD skip
this may sound funny, but it worked in my car, put a foam sleeve around it- so that the unit it sitting on the foam and not "hanging" there, the steadiness of the unit will help it not skip. you may even use the floral foam arrangement blocks cut down to size.
Nov 26, 2008 | Kenwood KDC-MP335 CD Player
Sound scatchy when paly music and copy data from CD/DVD at same time?
I believe that when copying cds etc you should not have any other programs running as to do so can effect the burning program the reverse may be true the burning program interferes with your sound program
Jul 04, 2008 | Intel D101GGC Motherboard
HAVING TROUBLE WITH CD DRIVE ON WINDOWS XP EMACHINES COMPUTER. SKIPPING AND DISORTED SOUNDS WHILE PLAYING A CD AND MUSIC OR SOUND THAT ALREADY ON THE COMPUTER. HAVR TRIED PURCHASING ANEW CD DRIVE AND...
It's not your cd-rom but more likely your speakers. Borrow or swap your current speakers that you know work & sound good.
If they sound good on your system. You need new speakers. If the sound is still disorted. Than your sound card can be
defective or the sound out-put jack is not getting a good connection. Without the Pc model number & Mfg's make I can not go any fauther with suggestions.
please vote...
Feb 13, 2008 | Computers & Internet
My benz in trunk cd changer skips....
Hi if you have cd lense cleaner try run it twice so that the small particles stick it lense will be remove .
also put some rubberized foam cushion around the cd if buit in.
Jan 30, 2008 | Sony XR-C6100 CD Changer
Creative sound blaster x-fi xtreme audio
Windows closing slow means you have a bunch of program that are running in the back ground. Windows has to close each before the system can shut down. To see just what is running in the back ground. Allow windows to completly finish opening. Click the start button, click run. In the window type, msconfig & click ok. System Configuration Utility window will open. Click on the Startup tab. Now you can see just what programs are running in the back ground.
Adding memory can also help speed up a slow pc & keeping the system clean by using the two programs listed next.
First. Run disk cleanup, a windows program found in system tools. Than run Defrag also found in system tools. Restart the pc when finished. This should help your system to run a bit better.
If you have the CD that came with the sound card uninstall the software through Add/ Remove programs found in the control panel. Restart the pc. Reinstall the drivers from the CD & try opening a few programs. Open & run the program your using to play music. Any better? If not try using another music program like iTunes a free download found here. http://www.apple.com/itunes/
You can also try the drivers from creative they may be newer than your CD here: http://us.creative.com/support/downloads/welcome.asp?action=next
Enjoy!
Please vote...
map9966
Jan 29, 2008 | Creative Labs Sound Blaster Live! 5.1...
Blank lines in printing
Funny problem. Did you try a driver update ? This will probably help
- Ranjit
ranjit@supportminds.com
Nov 08, 2007 | HP OfficeJet 7410 All-In-One InkJet...
E-Machines eMachines Desktop PC Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
