Question about Lexmark X4270 All-In-One InkJet Printer
All-In-One X4270 Not Printing
Have checked the usb cable connection, the power light is on. Those are the ony two. connections I have for the printer. I'm at this time not using the fax machine, (will in the future) Do I need anything else for connection for my printer? Lost the directions for installation. Hope you can help. The scaner is working but not the printer. I have also checked marked the defaul as Lexmark 4270.
  • Anonymous Feb 14, 2008
    I recently purchased a compaq pc.everything went well until i tried to print from my lexmark x4270 all in one printer, which will not print anything from window vista. what should i do?
  • Naochomo Feb 18, 2008
    The solution to purchase a driver or download was very good! That would have been a very good solution however, I discovered that my printer was telling me their was a paper jam, which their really wasn't but once I finaly got the printer to clear, the printer was just fine. I had pushed the paper a little too far in and the printer decided I had a paper jam. Oh, well, thanks anyway, for your great solution.
Dear guest, did you try the same solution as naochomo, a new driver to be compatable with vista?
Posted on Mar 12, 2008
    Sergeant:
  • 390 Answers
Windows vista is a brand new OS and many printer manufacturers have had to produce new drivers to run on these OS. I would visit lexmark website and download the new driver fo your printer and OS (vista).
Posted on Feb 14, 2008
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
Cant remember what cords are needed to connect my lexmark x4270
According to the Lexmark X4270 Specs page at Lexmark.com, this uses a standard USB A/B cable Click to See Example.
Be sure to get the A/B (or A Male to B Male) type cable. The two ends will look different from each other.
If you need a power cable, you'll need to contact Lexmark's tech support to find out what type you need.
May 18, 2010 | Lexmark X7170 All-In-One InkJet Printer
Printer won't print test page after downloading driver for x4270
-disconnect from computer
-perform printer self-test (refer to printer documentation)
-change usb cable
-try another usb port
Sep 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Computer wont communicate with printer
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
Disconnect your USB cable from your printer.
Uninstall all Lexmark printer drivers on your PC.
Download the correct Vista driver for your model.
Install the driver on your PC.
Important Notice -
Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
go to Lexmark website using this link: http://support.lexmark.com/perl/support/support.cgi enter your product number (X4270) and you will find your driver for Vista. Good luck.
Mar 30, 2009 | Lexmark X4270 All-in-One Multifunction...
Lexmark X4270 power light won't come on
Disconnected the printer from the computer...waited 30 minutes...reconnected and the power was restored. This was suggested by a tech friend who says that sometimes clears the memory.
Mar 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer not connected to computer
I don't think these do LPT printing but if it is, ensure you are using a bidirectional cable.
Otherwise, check the USB cable, and if you do reinstall; be sure that you didn't just put the printer back in the same USB port it was originally in or worse, leave the printer attached the whole time. Windows XP especially keeps driver files and settings specific to a particular USB device associated with USB port information in the registry, you may be putting whatever setting was messed up right back in.
Jun 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270......All in one....computer recognized it two days ago, but today it isn't doing anything. Can you help me?
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?...If it doesnt..then (Check if USB printing support,USB composite device are present in the Device manager...i.e Right click on "my computer" ikon-go to PROPERTIES-Hardware-Device manager-Click the plus sing near and check in the list )
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK 4200 SERIES
Hi anders2......
Check if u have downloaded the correct software from the website...there r tow versions for vista (64bit and 32 bit)...check if ur Vista is 64 or 32 bit and d\w the software.....
If u hvae downloaded correct printer then....
U can also try...
May 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer not working when hooked up to notebook
uninstall the driver completely,reboot the system,again install the driver first,connect the printer afterword.
thnx N
Jan 29, 2008 | HP Deskjet 3845 InkJet Printer
X4270
First off you need to connect the printer to your computer. Make sure the fax is plugged into the phone line. Then install the correct drivers for your printer.
If you have vista follow this: link click here
Attention Windows Vista Users
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Jan 21, 2008 | Computers & Internet
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
