Question about LG VX-8700 Cellular Phone
Lg 8700 Cannot keep my new jawbone connected with the cell. keeps dropping and then I can't even get it to connect. when i remove the battery on cell and restart it recongnizes the jawbone after a little of time it gives me the 3 beeps and disconnects. any help????
  • 4 more comments
  • Anonymous Feb 14, 2008
    my bluetooth would loose connection when I was only inches from the phone extremely frustrating!!! Then at times it would go into a continuous loop of audio transfered to phone and back again. The only thing I could do was to reboot the phone!!!!
  • Anonymous Mar 29, 2008
    same exact problem !!!!!
    tried with 3 different bluetooth headset same issue :-(
    any fix ????????
  • trp005 Apr 24, 2008
    I have my LG 8700 connected to my car UConnect system and it keeps disconnect. I soon as I try to call or I have an incomming call, the connection cuts...
    Any solution ?
  • Anonymous May 02, 2008
    Same problem and Chryslter admitted to me that there are known issues between Uconnect and LG 8700 phone.
  • daquilad Jun 16, 2008
    I aslo have an LG 8700 connected to my car UConnect system and it keeps disconnecting. In addition the radio does not come back on after a call is completed. Please help!!!
    Any solution ?
  • Anonymous Jan 24, 2009
    yep me too
After a while, the battery becomes slightly loose, so battery connection is intermittent. Simply put a small wedge (small piece of cardboard) at the top of the battery compartment, so that when you renisert the battery, it forces a tight connection on the bottom connector. I have fixed 5 phones this way. Intermittent connection causes the blutooth to drop, and battery to appear to not hold a charge well. THIS IS SO SIMPLE, yet nobody knows about this! It's worked on EVERY VX-8700 I've tried it on.
Posted on Mar 12, 2009
I recently went to the verizon store with this same concern, one of the associates told me that the lgvx8700 is known to have bluetooth connectivity problems. The best solution may just be to have the phone replaced. They ordered me a new one (refurbished i guess) and I will receive it within two days, hopefully the problem will be solved.
Posted on Jul 23, 2008
I have had the same problem and finally Chrsyler admitted to me (Jeep Grand Cherokee 2008) that there is a software problem between Uconnect and LG 8700 phones.
Posted on May 02, 2008
I have the same problem. Is extremely frustrating. Especially when there are times when I can connect and it stays connected for many consecutive calls. But if I turn off the jawbone OR phone. Its a less then 50% chance I will have the same success. I keep hoping for some sort of LG8700 fix.
A friend of mine had same issue with Jawbone and Treo smartphone. Switched to a Motorola Razr (For many other issues) and jawbone works perfectly.
Posted on Mar 31, 2008
Jawbone up wont charge
It may be the problem of the charger or the battery, please check them. If the battery is unable to charge or keep charge then replace it.
If the charger is unable to supply sufficient charge or no charge then replace it with a new one.
Jan 13, 2014 | Young Micro Ultra Slim Hard Shell...
Dropped my LG 8700 phone, and now it just keeps "searching for Service" Everything else seems to be working ok. Any suggestions?
If you're encountering this kind of problem on your phone then
all you have to do is powercycle your phone.You can do that by
removing the battery while the phone is on.After 15 seconds
kindly reinsert the battery and turn the phone on again.If you
still have the same error message then kindly go to a different
location because it might be that the phone is not getting a good
reception.And if you still have the same problem then kindly
contact your service provider because its a probable issue with
the network,not with the phone.
Thanks!
Apr 20, 2011 | LG Cell Phones
Pairing problem with lg chocolate flip phone
contact jawbone for further assistance because most carriers dont support bluetooth
Jan 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
Dec 31, 2009 | Apple iPhone 3G
Bought a new battery for my vz 8700 LG,installed, charged, now I have no screen, but the phone will send and receive calls.
hello
I think the problem is not about the battery.
The connector which connects the display to the central PCB is either disconnected or broken.
If you have some experience with phones you can open it and check it by yourself.
If the connector is fine and connected properly then check your display if it is working fine.
you may have to replace the display in this case.
Thank you
Aug 07, 2009 | LG VX-8700 Cellular Phone
Can't connect my jawbone with my phone
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY! "
Jun 02, 2009 | LG Vu CU920 Cellular Phone
I can't get ringtones on to my LG VX8700! (bell)
your going to have to go into Bitpim and manually set your Com Port where the phone is plugged into on your computer then it should work over bluetooth
Nov 27, 2008 | LG VX-8700 Cellular Phone
LG 8700
HAD THE SAME PROBLEM NOW ON MY 3 RD NEW PHONE LG IS A PICE OF SSSSHHHHHTTTTTT
May 09, 2008 | LG VX-8700 Cellular Phone
Compatibility with LG VX8700 - connects but won't work when button pressed
Seems I may have the same problem, I just returned the first Jawbone, second one is displaying the same problem - it pairs but then won't recognize or interact. Sad if it's my phone.
Jan 10, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
LG VX-8700 Cellular Phone Logo
922 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
