Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Signal board questions
Hi, I recently picked up a Hitachi 51F510 off craigslist for free because it does not work. The prior owner stated that coffee had been spilled and got inside the tv. They said a repairman looked at the tv and told them it is the signal board and it will cost about 800 bucks to fix. I looked at the signal board and it has a good bit of corrosion and is rusted pretty bad, thus supporting his theory. I can get a whole new board from circuit city parts line but my question is to someone who might know a little about this... I was able to remove the board myself and I am pretty sure I can install a new board. I do not have any experience with TVs. Is there anything I would need to know before installing the new board? I build computers and it appears to be similar to a motherboard on a computer and simple to replace.
Also, do you agree with the serviceman that this may be all that's wrong with it? The TV does absolutely nothing when plugged in. There is no evidence of any liquid damages anywhere else within the set and the fuses all appear to be ok.TV is very clean inside and out.
Thanks in advance for any help.
    Sergeant:
  • 395 Answers
Replacing the board requires no set up so it should run after replacement. as for the other problems that is unknown until you replace the parts you know are bad. it tough to say if any other boards were affected.
Posted on Feb 14, 2008
HITACHI 51F510 SCREEN ASSEMBLY
The Hitachi site may have this available or you can Google the model number to see if you can locate one for free.
Front screen unit with frame is removed from the front but there are pitfalls to avoid when replacing the screens.
May 20, 2012 | Hitachi 51F510 51" Rear Projection...
NO PICTURE MODEL 51F510 HITACHI
hitachi is known for bad solder connections on plug connectors between the two main big boards
Nov 11, 2009 | Hitachi 51F510 51" Rear Projection...
Power outage.. volume not as loud as before..part bad??
Yes the audio board is going bad there is a capcitor on that and it would need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 21, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 CONVERGENCE ISSUE
Check the Blue CRT drive board for defective solder joints especially at the CRT socket
Feb 03, 2009 | Hitachi 51F510 51" Rear Projection...
Blue Hue and lines on HDTV
what more can you describe as to the fault of the unit.is the blue hue there on all inputs and tuner mode and the lines are they also blue in color .
Apr 06, 2008 | Hitachi 51F510 51" Rear Projection...
RePost:Hitachi 51F510 W/ No Power HELP
The convergences amps are found either on the neck of the CRTs, or a seperate board directly connected to that area via cabling, depending on version of chassis...accordianman
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51f510 unit has no picture
Is set coming on and no pic or not coming on at all.
Dec 21, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51f510
read threads here or at ctechnicians.com
Dec 12, 2007 | Hitachi 51F510 51" Rear Projection...
Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Aug 16, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
591 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
