Question about Logitech (980174) Headset
Broken wires the sound stop comin out so i opened it and noticed the wires covered in rubber where loose where do the go and how do i fix it
  • 3 more comments
  • jmany666 Apr 01, 2008
    The three wires inside that connect the earphone and the mike together are severed.
  • Anonymous Jul 23, 2008
    i need the blue prints so i can solder the wires back together in the right place
  • Anonymous Oct 07, 2008
    my logitech
  • aad_alf_3 Oct 07, 2008
    my logitech is broken you know the wire of the headset the long wire where u connect the usb yeah its broken the wire came off so i need help
  • kikk836 Feb 15, 2009
    my head set just stoped working when i have it in its as if it wasnt in the usb port for my ps3
  • 2,130 Answers
The wires should be soldered to the speaker terminals. There should be (2) terminals on each speaker.
- Jim
Posted on Feb 14, 2008
No power to my headlights or wipers
it sounds like you have some loose wires, or bad ground since you found the place that when tapped does something, first thing disconnect your battery, neg first, the pos, there should be a couple of bolts holding down the fuse box, take them out, now if you can turn it over, or try to locate the wires hooked up to the one fuse you were tapping, checking those wires to make sure they are good, not rusted, broken, bare , and tight, fix if not if not, then check the bus bar on the fuse box, this is were the pos cable from the battery goes, sometimes these come loose, break, and can cause all kinds of things also check your ground wires, to make sure they have a good ground
Dec 05, 2013 | 2002 Nissan Altima
Power windows and locks stopped working but only on the driver side
open driver's door, and check wiring between the door and hinge pillar due to open and closing the door, the wiring will break, use a razor knife and split the rubber cover and check for a broken wire, solder as needed. if no wire is broken, suspect master switch on the driver's door.
Jul 27, 2010 | 2006 Chevrolet Trailblazer
Brush does not spin all the time
HighnTools posted this solution a while ago. This might be related to your problem:
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
The above was from HighnTools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Power door locks quit working on drivers side switch. Next day lowered power window now I can not raise or lower any windows from any door switch
You may find broken wires inside the rubber wire cover between the door hinges.. the wires break due to flexing when the door opens and closes .. repair by soldering and heatshrinking the wires back together,,,and this will fix all NOTE ....You can use crimp connectors but they dont offer any protection to the connection and the wire will break at the connector at a later date ....Good luck
Dec 05, 2009 | 1999 Dodge Durango
All of a sudden i can not open any of my powerwindows they just stopped working
It sounds like a fuse blew. Check your manual for the fuse location and check there first.
i hope this solves it,
matthew
Oct 23, 2009 | 2004 Jeep Grand Cherokee
My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Sep 17, 2009 | Kenmore 83142 Electric Dryer
When I vacuum the carpet it won't engage into the brush mode, or it does intermittenly. It stays in the brushless mode for the most part
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Aug 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Mouse stopped working
My daughter's Vtec laptop had the same problem. The black wire in the base of the mouse had broken off and had to be re soldered. To open the mouse pad remove the four rubber feet under the mouse pad. Use a small screwdriver to remove the four small screws and then lift off the cover. Check all the wires to see if any are loose or broken. There are two small circuit boards inside. The black wire I mentioned connects to the smallest circuit board and the solder connection is on the underside of the board.
Dec 27, 2008 | Vtech Tote n Go Laptop Plus
After timing chain replaced catalytic convertor light on
recheck wires all back on to sensors,sounds like one is loose or terminal connector block has a broken wire behind the rubber cover
Nov 26, 2008 | 2000 Jaguar S-Type
Logitech (980174) Headset Logo
359 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
