Question about Dryers
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
Recently, my dryer has stretches where it doesn't start when we turn the Start switch; instead, just hums. Humming sound appears to be coming from 'inside' the dryer, not right at the switch. Have tried cycling from one cycle to another, opening and closing door - nothing. Some time later, we can return to the dryer and try it again - voila! all's working again. Am wondering if I have a dying Start switch? I have the same problem, but I can not find a part on a parts list for a motor capacitor. I have a GE DVL223EA0WW. The motor just hums when turning on the switch.
  • Anonymous Mar 18, 2014
    motor(279827) hums, will not start. replaced door switch and motor(8538262). now it does nothing.
    President:
  • 1,314 Answers
Might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Posted on Feb 15, 2008
AC induction motors do no have armatures.
Posted on Apr 16, 2008
2 Suggested Answers
  • 1462 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Posted on Mar 28, 2007
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | GE DWSR463EG Electric Dryer
Ge dryer not turning. tries to start making a humming noise. doesn't turn.
check the belt and tensioner, make sure the belt isn't broken and if not , make sure its tracking correctly
Jun 16, 2011 | GE Dryers
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
Start switch hums, does not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 01, 2010 | GE DWSR405EBWW Electric Dryer
My dryer Start Switch will turn on and hum but will not keep the dryer running. Could this be only the start switch and is it simple to change?
Unfortunately it is not the start switch that causes these symptoms. It is the drive motor itself.
The motor is pretty difficult to replace on this unit but if you have a lot of time, patience and mechanical ability you can do it. The cost of a GE dryer motor is about $175.00
Apr 24, 2010 | GE DRSR483GD Gas Dryer
GE Dryer won't start without help
YES THE MOTOR IS BAD,TO WEAK TO TURN DRUM ON IT'S OWN,IF YOU GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR MAYBE YOU CAN FIND ONE CHEAP ON EBAY-MIKE
Mar 05, 2009 | GE Dryers
GE dryer has trouble starting.
heatman101
Jan 20, 2009 | GE DBL333EA Electric Dryer
Clothes dryer
dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt. It will take care of your problem
When I try and start my ge dbb3300eaoww dryer it buzzes as if it wants to start if I spin it with my hand it will work. I put a new belt on it and it does the same thing.
Motor start switch is bad. This is typically replaceable with out replacing the motor.
Will take care of the problem.
My drum will sometimes stop turning in the middle of a cycle, and the motor just hums. I pause the dryer, open the door, rotate the drum, unplug and plug the electrical, and then it will usually complete the cycle. Does that mean the belt is "occasionally" slipping? How do I check this?
Replace the belt. It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time. This will take care of the problem.
Sep 15, 2007 | Dryers
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
266 people viewed this question
Top Dryers Experts
Marvin
Marvin
