-   This used to work but stopped (Model# 81-166-0257) so I bought a new one. That didn't work, either, so I took it into Data Doctors and they were able to upload pictures from my tower but I wasn't. They said it's working fine but when I try to do the SAME thing they were doing, it doesn't work and I Hate going to Walgreens because their software totally sucks. I'm not sure what to do on this model#. -   CubsFanatic
Some older tablets do not recognize SD cards over 512MB. You can get a small USB device at WalMart for about $8.95 that will solve this for any PC, on any size card.
My tc1100 will not see my 2GB SD card but does fine with the device. It is the Digital Converter SD/MMC reader/writer from Digital Concepts, model # CR-35TD-R. Includes a short USB extension cable, very handy. It's barely bigger than the card except for the USB plug. You will hardly notice it in a pocket.
My tc1100 has no trouble with any SD card up to and including 512MB. My tc1000 (no SD slot) works fine with the device in a USB port and will see any size card.
My wifes 2 year old HP SlimLine has the same trouble, this fixes it.
Blaino
the scren resolution is set too low, even when re-set. The only way to get th tablet to start with...
(More)
the scren resolution is set too low, even when re-set. The only way to get th tablet to start with the right resolution is to switch on and off, but this may take 50 to a 100 times
The power plug appears to be bad.(Or the battery?) When the adaptor is plugged in, the "plugged...
(More)
The power plug appears to be bad.(Or the battery?) When the adaptor is plugged in, the "plugged in" light does not light. Is it possible the battery is bad? If not, is the plug the likely issue? Can it be repaired? Do you have the parts?
i lost my stylus and cannot find another i was wondering what hp tablet stylus can i use in place of...
(More)
i lost my stylus and cannot find another i was wondering what hp tablet stylus can i use in place of it . is the 4200 stylus compatiable .
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
