Question about Lexmark X4270 All-In-One InkJet Printer
Missing installation disc
I can not print, scan or fax from my computer. I was wondering if it had something to do with compatability with my compac wf1907 home vista computer.
  • 390 Answers
Yes, this just might be the issue!! Many printer manufacturers now have to cope with the new vista OS and produve drivers to suit this. Download the vista driver fo your printer off lexmark website. Befor this, jsut check to see if the printer preferences is checked to work offline or something similar. Sometimes a little setting is all that is the problem.
Posted on Feb 14, 2008
How to print? how to clear print jobs in queue? how to unpause fax setting to send fax?
to find the task list for the printer go to the control panel of the computer , go printers and faxes, right click on printer, right click on properties and the print list will come up
highlight and delete and tasks that are holding up the printer
you may also find a compatibility tab there so check that the printer is compatible to the pc
Did you install the driver for the printer from the disc supplied with the printer
You may have to install the fax into the pc as well
however there is a fax operation in the pc where you make up a document , put it in a folder and right click the folder and send to fax , e-mail recipient etc
the user manual with the printer will explain most operations
Nov 29, 2015 | Office Equipment & Supplies
The Fax driver was not installed when I installed the Lexmark X2500 all in one from online
If you still have the installation disc that came with your printer, please insert it in your computer hard drive to install the Lexmark fax software.
If you don't have the disc, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Nov 11, 2011 | Lexmark X2500 All-In-One Printer
My printer is printing but i cant scan my documents - no compatible printer installed
Make sure the Lexmark OCR scan software (used to scan documents, convert into PDF file or create multiple pages into 1 file). The software is available on the installation disc that came with the printer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your problem, your rating will be greatly appreciated. Thanks.
Oct 20, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
I can't scan with my Lexmark 2600m All-In-One Printer. I think there may be missing programs on the computer. When I press the scan button, nothing happens on the printer or the computer. It prints...
Make sure the Lexmark OCR scan software is installed on your computer. The scan software is available on the install disc that came with your printer. If lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 26, 2011 | Lexmark X2600 InkJet Printer
I have a Compac computer with Vista. My old
maybe that is a twin driver problm go to the start of your computer and find the twin settings and select the driver the name of your scaner din try to scan
or try to uninstall the printer driver by using ad and remove program
and install it again.. thank you..
Jul 04, 2009 | Computers & Internet
Installing printer to mac.
On Mac, You have no silly popups when you print something, instead you'll just see the printer icon in the dock, or bouncing if it needs your attention, if you installed the drivers, and you can print, and all other functions work, that's all that matters. Search Apple or your manufactures website if you want additional scanning / faxing software if needed. Also, info about your printer is found in System Preferences --> Printers and Faxes (or similar name) and double click your printer, other wise, use the buttons below for other options.
Apr 28, 2009 | Computers & Internet
Not Printing Anything
Dec 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site.
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
