Question about KitchenAid KESC307 Electric Kitchen Range
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
It is a Tappan with a self-cleaning oven. The model number is: TEF355BFWA. The serial number is: VF74418035
    President:
  • 1,314 Answers
What do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Posted on Feb 14, 2008
F90 flashing
Hi Cathy:
F90 Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
- unplug the range and wait 1 minute.
- turn the range back on, then while holding in on the oven door.
- start another self clean and wait 2 minutes, then cancel the self clean.
Do not release the door until the door lock light goes out.
Hope this helps.
Dec 30, 2011 | Tappan Kitchen Range
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    Self cleaning oven
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    May 10, 2010 | Tappan TEF242 Electric Kitchen Range
    When cleaning the stove i touched my accident the
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    unplug the range.
    wait 1 minute.
    start another self clean.
    wait 2 minutes.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
    Oven door locked will not open
    try putting the stove in self clean when it goes in for about 1 minute cancel the self clean see if it opens.
    Nov 30, 2008 | Tappan 30IN ELEC IGNa Oven
    Tappan self-clean oven door locked shut, fan keeps running
    Did you give it time to cool down? If so, probably a control issue.
    Sep 01, 2017 | Tappan TGF320 Gas Kitchen Range
    Self-cleaning gas oven
    Door lock motor has probably failed.....Self clean on many
    ovens can be a self destruct mode. Door latch motors, sensor
    probes and even the electronic controls can be destroyed by
    this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
    Jun 02, 2008 | Frigidaire Ovens
    Tappan electric range door locked
    Check the door lock switch/solenoids. You'll have to unplug the range/stove. Remove the solenoid and check to see if it has continuity or if the solenoids are stuck.
    You also might have luck resetting the clean cycle. Even though the lock is engaged, try to open the oven door a little. Start the clean cycle, then cancel it.
    Dec 13, 2007 | Kitchen Ranges
    Tappan electric stove designer series
    the cleaning light and the lock door light doesn't go on when I set them to self cleaning and lock the door what should I do
    Nov 17, 2007 | Tappan 30IN ELEC IGNa Oven
    KitchenAid KESC307 Electric Kitchen Range Logo
    374 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Marvin
    Marvin
    Colin Stickland
    Colin Stickland
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
