Belt will not fit to motor and drum pully
Got new belt for hotpoint wf440g washing machine and it will not fit. Size of belt is EPJ1158/456EJ, old belt was 5PJE1158. Will this make a difference?
    President:
  • 1,314 Answers
Did you loosen the adjusting bolts on the bottom of the motor and slide it in a little
Posted on Feb 13, 2008
Hotpoint drive belt
un plug appliance, remove lid and back plate, place belt on motor and carefully on drum pully, turn pully to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i go about replaceing my washing machine belt
If your machine is a front loader, then you will need to remove the rear panel, normally this is just a screwdriver requirement. make sure you take your old belt as the supplier will require the numbers from it to ensure you get the correct size. There are many different belts. Place the belt onto motor shaft and then onto drum pully wheel as far as it will go. You then need to rotate the drum by hand to feed the belt onto the wheel. After you have done this you may need to line the belt up by moving it across the grooves on the motor spindle. to do so again move the drum pully around and at same time move belt across the motor pully groves until belt runs central on drum pully. This may seem awkward but you will be suprised how easy it really is.Also it will save you a fortune by doing this yourself
Mar 13, 2010 | Washing Machines
Belt came off hotpoint washer
hello mam
before trying please check the belt tension. and if you inspect the threads are visible on the belt which will be seated on the pully please change the belt and to put it back
1.plase the belt into the motor pully first. and then using a screwdriver hold the belt into the drum pully slowly rotate the drum as you rotate the drum you should hold the belt along the pully.
Oct 04, 2009 | Washing Machines
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
Hotpoint wf240 replacment of belt, i cant get it on.
Hi, put the belt on the bottom pully and feed the rest up to the top pully, fit the belt on to half of the top pully, now open the door of the washer and very carefuly turn the drum while holding the belt tight to the pully, take care not to get your fingers trapped, make sure that the belt stays on both pullys by rotating the drum by hand a few times, if it all looks ok and central then the jobs a good un.
Mar 03, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Belt replacement
belt is a streach fit
put belt onto motor pully first then feed belt round drum pully
Aug 16, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoit belt
Feb 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
