Question about Dell Dimension 4600 PC Desktop
Installing XP on a dell computer
My XP installation hangs when it gets to the copying of the files to the hard drive. The computer only allows a startup disk so I use windows 98 startup disk. This means I am trying to start installation of XP from DOS. When I type winnt the installation goes to copying files and then hangs. What is the special code I can use to get it to install by itself? (winnt /s /x)
  • Anonymous May 21, 2008
    May i ask something? How about if your installer is a non-bootable disk?
    Sergeant:
  • 336 Answers
Go to a computer that works and put in your hard drive. (whivh I don't recomend unless you are a technician) Boot and install through the slave drive ie the one you put in. If you need more detailed solutions you can e-mail me at 4077mashunit@gmail.com
All The BEST,
RCF
Posted on May 27, 2008
  • 58 Answers
Try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Posted on Feb 14, 2008
When trying to reinstall windows xp, the process keeps failing during setup saying, "The file comct132.dll was not copied correctly. The file Setup on your hard drive is not a valid Windows XP system...
Click start/run Type: cmd
In the Command window type:
SFC /scannow Note the space between SFC and /scannow
You can copy/paste: SFC /scannow
Hit the Enter button
keep your xp cd handy in case you're asked to chuck it into your cd rom
The above should replace missing files and get you to the place where the install can proceed.
Let me know. __________________
If this doesnt work,yes hard drive needs to be replaced.internal hard drives are system specific.u need to contact dell tech support to get the right specifications
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
Dell 6400 hangs and then crashes
Try replacing or upgrading your RAM it sounds like your PC is overworked and the bsod is probably a result of data loss due to low ram
Aug 18, 2008 | Computers & Internet
Cant format my C drive
Sounds like the hard drive might be going bad....but you did say everything copied okay.. maybe you could try installing a different operating system on the partition or using an ubuntu live disk or another utility to reformat the partition before reinstalling windows. Is data loss an issue? Let me know if I can clarify anything.
Oct 26, 2009 | Microsoft Windows XP Professional
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
One day my Samsung SP0822N running XP as master died on me....
You will have to provide a driver to XP when you're installing the OS that allows it to "talk" to the hard drive. When you are going through the setup of XP, you will see a screen that gives you the option of pressing F6 to install a custom driver. You must press F6 (and you don't have but just about 3 or 4 seconds to press it) and then tell XP where the driver is it needs to load.
Put the driver from Samsung on a floppy disk (if you have a floppy drive available during the installation process) and point the install of XP to the floppy. It will copy that file into memory and then proceed with copying some other files. Do NOT remove the floppy until after the installer has rebooted the machine and copied the files over again.
This should allow you to continue with the installation normally.
Mar 21, 2009 | Samsung (SP0822N) 80 GB Hard Drive
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell dimension e520 reinstalling the XP Media center
connect your hard drive to other computer and then have it clean by scanning with antivirus. and then copy the important files on it to the working computer. after copying the files thats the time to return back the original hardrive to the dell dimension and then reformat and reinstall the system again again. please use original operating from dell or what ever is applicable.
mlenavz
Jan 31, 2009 | Dell Dimension E520 PC Desktop
Installing Windows XP in place of Kylin OS
If you have a copy of MS-Dos should work. The hard drive needs to be reformatted. This should change the File Allocation Table (Fat) and allow you to install Windows XP. Hope this helps.
Nov 17, 2008 | Computers & Internet
Problem loading windows xp
try disabling legasy USB devices in bios
Jul 09, 2008 | ASUS K8V-MX Motherboard
Windows XP Service Pack 2 shows asms missing
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Feb 05, 2008 | Microsoft Windows XP Professional With...
Dell Dimension 4600 PC Desktop Logo
98 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
