Question about Refrigerators
Kitchenaid My ref/freezer which still works OK feels warm>>>hot to the touch. Especially on the front perimeter (4 inches around the sides and top) and between the ref/freezer doors (center divider). The is a slight burning smell and items in the ref occaisionally freeze.
  • kovi0801 Feb 16, 2008
    I cleaned the unit and the fan seemed like it was sticking. After claening it started to spin and the hot compressor cooled along with the sides/front of the refrigerator. A few days later the sides were hot again (sticking fan?). Not sure if I need to replace the fan (probable) or if there is a connection on the compressor that tells the fan to start bad?).
    when you say "no", you mean "no" that there is not a connection which may be bad to start/stop the fan. Is that correct? In short, my problem is more than likely the fan.
    President:
  • 1,314 Answers
Advise
Posted on Feb 13, 2008
  • 1 more comment
  • robert samples Feb 13, 2008
    pull the unit out and see if the cooling fan for the compressor and condenser coils are running then unplug the unit and clean the coils the hot areas you describe should be hot but not too hot thats whats called a youlder loop to keep the door gaskets dry so they dont mould let me know what you find
  • robert samples Feb 16, 2008
    no the fan should run anytime the compressor is on if its sticking replace it asap dont forget my other box its helps our ratings for the people who dont answer us thanks
    yes thats right if the compressor is on the fan should be too if the comp is off so should the fan
Freezer runs and sides are hot
Good Morning bigred140, thank you for allowing me to assist you!
From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around your refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can typically locate one on the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your freezer) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Best regards, Chris.
Dec 22, 2013 | Frigidaire FKFH21F7HW Freezer
Sides of upright freezer are very warm to the touch
Good Afternoon Chuck, thank you for your inquiry! From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the freezer. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
Aug 21, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Should gaskets around ref and freezer doors be quite warm?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Sep 01, 2011 | KitchenAid Refrigerators
Is it normal for the outsides to get very hot
No. If you feel the sides getting hot, it usually means that the ref. isn't cold enough inside. There us either an electric heater or a pass of the hot gas from the compressor around the edges of the doors as well as the mullion between them. If they feel hot, it's too warm inside.... Check the ice cream: It's the 1st to go.
Oct 25, 2009 | Frigidaire Freezer Refrigeration White...
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Sanyo Ref heating/warming of the case and body
this is not a fault. some of the hot pipework is led across the sides and across the transom between fridge and freezer to prevent condensation
Dec 01, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
245 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
