Question about Mitsubishi HS-HD2000U VCR
Using the Misubishi HS-HD2000U
HELP! I have purchased this HDVCR abd I cannot seem to get it to record in Hi-Def. I am using the firwwire cable hooked to my Mitsubishi DLP fire wire connection but I don get anything on my screen except for a blue display. I am trying to record off the Local Hi Def channel but when it starts to record it stops.??? I have tried different hook-ups but I can't seem to get it. Any Ideas? It's probably me.
Thanks accordianman. I haven't tried that yet but I will.
Posted on Feb 18, 2008
  • 979 Answers
The connection "chain" that you need to have set up is as follows: First the source goes to the HD VCR, then that output goes to the TV...accordianman
Posted on Feb 15, 2008
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
My Mitsubishi HS-HD2000U D-VHS is only playing back in mono and not stereo/Hi-Fi .
you need to remove upper cover and clean tape head area by a clean **** of oslo band paper. any clean white band paper can do. don't use clothe, it can damage head chip.
Apr 05, 2010 | Televison & Video
Can get analog stations recorded but not hi defination
Hi, unless the VCR/dvd recorder is hi def then you won't be able to.
Hdmi connection is hi-def, I think you can have a hi-def signal through composite, but it's your recorder thats the problem, it cannot read the number of line a hi-def signal has.
I have just found this.
http://www.brighthub.com/electronics/home-theater/articles/48499.aspx
I hope this helps.
Regards - Anthony
Feb 09, 2010 | Toshiba Televison & Video
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hooking up hdmi cable from laptop to tv
yes it will. when u plug in the HDMI. right click on your desktop and adjust your graphic properties for your secondary screen
Jan 03, 2009 | Tivo Series2 TCD649080 Video Recorder
Hooking up laptop to hdtv with hdmi cable
Only if your graphics card can handle HD viewing
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Hi-def to standard def
transfer by I-Link to downconversion
Jul 05, 2008 | JVC Everio GZ-HD7 Camcorder
Televison & Video Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
