Question about Asko W6021 Front Load Washer
How do I remove the front control panel?
I need to do this to fix the LED power on light and the program control child lock spring both of which have become dislodged during transit. I've removed the drawer, the control knobs, and all the screws in the front panel but the panel doesn't budge. Are there plastic locking tabs or something?
Thanks in advance. Jon.
  • Jon_hurn Feb 21, 2008
    Thanks anonymous111 - that did the trick nicely. Managed to remove the panel withou breaking a single lug. LED and temperature control lock now fixed and machine back to original condition.
    Cheers. Jon.
  • 49 Answers
Remove the 3 screws at the rear top to remove the top cover. you now have access to back of control panel. tou should see some plastic lugs sticking out through metal clips. you will have to force the lugs through the clips with a flat blade screw driver. be careful it is easy to brake them
Posted on Feb 19, 2008
The CHILD LOCK light came on and I cant get it off. Pressing CANCEL does nothing. How do I fix it?
Usually you need to press and hold a button or a pair of buttons to toggle the Child Lock function. Without the model number of your dishwasher, I can't be sure if this will work on your machine. It did work on the old Kitchenaid I had. Press and hold the Energy Saver/Dry button for 4+ seconds. If the light goes out, you have released the front panel lock.
On some models, you needed to press and hold the Air Dry button. However, you may need to look for writing in a small font that will indicate the correct button/key combination to release the front panel lock.
If pressing the appropriate button for an extended time doesn't work, then your keypad may need to be replaced. The signal isn't being received by the control of the dishwasher. (Alternatively, the wiring between the keypad and control unit or control unit, itself, may have an issue.)
I hope this helps.
Feb 26, 2016 | KitchenAid Dishwashers
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
Feb 01, 2011 | Televison & Video
HE3 front load washer has "control Blocked" light is on. No button works on control panel.
You have locked the control via the "Child Lock." Look for the button with a small padlock icon on it, press and hold for about 4 seconds to unlock. That should fix ya!
Sep 11, 2010 | Kenmore HE2 Plus Front Load Washer
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control locked led indicator is on ,there no contol at all
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You dont want kids bathing in the machine, no. Pl rate me nice.
May 13, 2009 | Whirlpool GHW9100L Front Load Washer
Error code EO -F2_
It means that your control panel went out and you need to replace it. Here is how if you want to try your self.
The control panel is not available as a complete part.
To replace the control or touchpad, pull the range away from the wall and disconnect the power to it. Remove the cover on the rear of the control panel. Remove the screws that hold the clock or control to the front wall of the control panel. These screws also hold the touchpad to the front of the control panel. The touchpad connects to the control with a ribbon connector and there is a locking tab holding the ribbon connector to the control. Lift the locking tab and unplug the ribbon.
Dec 18, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Help me please................................
Usually, once child lock is on, the set will not respond to the front panel buttons and you need the power button on the remote control to turn the TV on. Then go into the menu and turn child lock off.
Mar 31, 2008 | Sansui H TV2600 TV
Control lock light is on , washer won't start
your controll is in child lock turnning power off wont fix find the lock button and push hold till light goes out
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Asko W6021 Front Load Washer Logo
256 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
