Question about Refrigerators
Kitchenaid Side by side refrigerator/freezer
My ref/freezer which still works OK feels warm>>>hot to the touch. Especially on the front perimeter (4 inches around the sides and top) and between the ref/freezer doors (center divider). The is a slight burning smell and items in the ref occaisionally freeze.
  • kovi0801 Feb 16, 2008
    cleaned the unit and the fan seemed like it was sticking. After claening it started to spin and the hot compressor cooled along with the sides/front of the refrigerator. A few days later the sides were hot again (sticking fan?). Not sure if I need to replace the fan (probable) or if there is a connection on the compressor that tells the fan to start bad?).
  • Anonymous Mar 27, 2008
    Exact same problem- the center divider and top border over the freezer regularly gets very, very hot. It occasionally cools off but then gets very hot again, hot enough to burn one's skin to the touch.
    President:
  • 1,314 Answers
When is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Posted on Feb 13, 2008
  • jgregory5685 Jun 09, 2011
    There wasn't a lot of dust behind the refrigerator down by the coils. I cleaned the coils and all other dust surrounding the area by the coils, fan and the condensing unit. I did not think that the fan was working, so I put a fan on the outside but in front of the condenser coils and the side of the freezer door was not as hot when I originally touch it. I might need a new fan.(?) Will check the side of the freezer tommorrow and see if it cooled down. I also have water in the drip pan. Is that normal?
12 year old GE ref side by side both sides warm
has cleaning the condenser coils helped out? does the condenser have a fan? if so when the compressor is running it should be running also. is the compressor hot to touch?
May 20, 2014 | Refrigerators
The ref. is warm the freezer side melted and the ref. side is cool took off back panel i think it could be the condenser is is very hot to the touch i hear a clicking sound what is going on
Hello and sorry to hear about your problem. It sounds like you have a general compressor or control card failure.
You will need to call a service person.
I have tried to help you. please help me by Vote/Rate my response thanks.
If you live in the Denver area, I can help you.
Dec 21, 2010 | KitchenAid (KSRD22FKST) Side by Side...
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hot metal between units.
Warm is ok for a temperature barrier , but , hot , usually indicates a condensor fan ( compressor fan ) not working , or dirty coils .
Jul 11, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Sanyo Ref heating/warming of the case and body
this is not a fault. some of the hot pipework is led across the sides and across the transom between fridge and freezer to prevent condensation
Dec 01, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
727 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
