Question about Refrigerators
Ice & water dripping in refrigerator
I have a Whirlpool frost free fridge that is about 15 years old with freezer on top. Trouble is I can't afford a new fridge at the moment and I'm a techo-idiot in this field..
Ice keeps forming at the fridge section vent at the top rear centre and water condenses (often quite a bit) on the ceiling dripping onto the shelves etc.
The temperature dials sometimes stick a little (mostly the freezer dial) but work with a tiny bit of pressure - don't know if there is any ice forming in there or not.
The freezer section is fine but ice cream does get too hard presumably because of the problem in the fridge section. No ice forms in the freezer.
The seals probably need replacing.
I have left it to defrost for over 24 hours with the doors open and dried it thoroughly. I tilted it slightly back and forward to try to get all the water out I could. The problem just recurred. I have also left it to defrost for shorter periods.
I've read a few solutions - door seals, regassing, taking the freezer apart to defrost the hidden coils with a hair dryer, etc.
Any ideas out there before I start paying money to have the mechanics investigate, or try to find the moeny to buy a new fridge?
Thanks for any help anyone can give.
  • aussie3 Feb 13, 2008
    Thanks Roger,
    If you're talking about the little removable plastic drain next to the vent I've done that.
    I can't see any other visible drains anywhere so I presume they're internal somewhere.
    Cheers mate.
    Colin
    President:
  • 1,314 Answers
Ok your defrost drain is frozen take the back panel off in the freezer section under the coils you will see a silver pan if its frozen it will be a block of ice you have to remove the ice then make sure the drain and tube are clear all the way to the pan at the bottom you should see the plastic tube on the back of the unit in the center over time algae can grow in the tube blocking it drying the unit will help but soon as it defrosts the tube fill up again and the problem reoccurs you kinda got to snake it out so to speak.the best way to deal with it is to go to lowes or home depot and get a eurka 302 enviro hand held steamer an investment but a great product to have around the house cost about 40 bucks but 1000s of uses
Posted on Feb 14, 2008
Drains plugged up. blow through it
Posted on Feb 13, 2008
4 Suggested Answers
SOURCE: Ice & water dripping in refrigerator
hi , roger here i am a maintenance tech for an apartment complex that just happens to have whirlpool appliances. the way i see it is the most likely problem you have is a clogged drain. if you push the refrigerator out where you can access the back of it you will see a plastic hose that runs from about the middle of the fridge down to the bottom and then dumps into a pan that sits on the top of the compresser. the easiest thing to do is to remove the hose from the pan and blow hard through it or hook an air nozzle from a compresser and blow through it . it should take care of it. also try to avoid turning the fridge up on its max settings. hope this helps.
  • 110 Answers
you have a clogged evap. drain and if you want the probelm to go away you need to that the back panel off of the freezer, then use a hair dryer to melt all the visible ice then use boiling hot water to flush the evap. drain tube which is also clogged with ice . once water flows all the way throuh the pipes as if you have flush the tiolet you have then cleared your issue
Posted on Jun 01, 2008
  • 16 Answers
Seems that you now have to little gas in the fridge.Somewhere on your apparatus there should be a factory tag where it should be info on amount of gas, prod date etc and also which type of gas to fill.
Other thing as fan not running properly,door gaskets leaking can lead to Ice build up.
High humidity and water all over inside fridge.Gas filling procedure.Make vacum(vacumpump)Fill in correct weight (grams or oz)of gas.Anyhow when you must fill gas there is usually a leak in your system and to find that i use liquid nitrogen.For this serviceman is the best option.
Regards. jan(Norway)
Posted on Feb 13, 2009
The top freezer is frosting up. While looking inside the main fridge, in the back there are two square openings. One is dripping water, the other frosted up. In the back of the freezer there appears to be...
drain tube froze up also not allowing water to drain into the bottom drip tube but ur problem is that the fridge didnt automatically defrost so what i would do is call the place where u purchased it and get them to check it out cause it should still b under warranty
Jan 24, 2011 | Whirlpool ET1MHKXM Top Freezer...
HOT POINT FRIDGE - FREEZER DRIPS WATER
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Feb 12, 2009 | Whirlpool GD2SHGX Refrigerator
Jun 01, 2008 | Refrigerators
Feb 13, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
2,772 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
