Question about Microsoft Office Professional 2007 Full Version for PC
Envelop creation whether copied from document or typed in separately, address is double spaced.
  • 265 Answers
Try typing the full address in a normal Word document, then select the entire address, then choose 'Mailings' tab, then 'Envelopes' on the left, then 'Add to Document.' Be sure to type in your return address before pressing: 'OK.'
Posted on Feb 14, 2008
Hi could you please let me have acsess to your stoves 720 ef manual ,
Yes. Someone converted it to a pdf document which I now have. if you need a copy, you will have to supply an email address and I will send it to you. If you are worried about disclosing the address, do not do it in one continuous line. Put the supplier like yahoo.com or whatever first and then on a separate line just type the address in a sentence, making it obvious to the reader what it is but not readily recognisable.
Jun 17, 2011 | Stoves 720EF Electric Double Oven
How do I change line spacing from double to single spacing? Whenever I commence to write a letter the second line is at double spacing as are all succeeding lines. How do I get it to single spaced lines?
Open a NEW, CLEAN document. Alter all the paragraph setting until you get them exactly as you want them.
Now the tricky part.
Save the document as a TEMPLATE and save to a folder you are familiar with. Give it a good name and below that on the dialog box, choose TEMPLATE (file type dotx)
Next time you need to type a letter with single spacing, open that template. When you go to save it, Word will prompt you for a file name as a docx, thus preserving your template for another day.
Feb 22, 2011 | Microsoft Office Word 2007 Home and...
Hi, I print a business letter in word2007 & every time, the inside address block is double spaced. So is the address heading.
I checked my Microsoft Word 2007 for a resolution I almost messed up but fortunately I figured it out. Highlight the portion that's double spaced and on top of the MS-Word document select the No Spacing option as shown on the image below.
I hope it helped you. Rate for this information will greatly be appreciated. Thank you for choosing FixYa!
Jan 11, 2011 | Microsoft Office Word 2007 Full Version...
I am trying to type a draft on my yahoo email and I need to double space it. How do I activate this please? Thank you. Joan.
I suggest that you create a letter or correspondence in word document and copy and paste it all to the the yahoo mail. So you can get 2 spaces.
Nov 13, 2010 | Computers & Internet
Message on screen says "can't unlock maps". What should I do?
    • If you see a "Can't Unlock Maps" message, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
2. To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it, connect the satnav to your computer and go to www.garmin.com. Select your country from the drop-down list and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
3. Retrieving your unlock codes:
  • Log into your myGarmin account
  • Select Manage Maps
  • Select Details
  • The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  • Plug your Garmin device into the USB port
  • Double-Click on My Computer or Computer located on the desktop
  • Right-Click on the Garmin or nuvi drive
  • Click Explore
  • Double-Click on the Garmin folder
  • Right-Click in a blank space in this window
  • Move your mouse over the word New
  • Select Text Document
  • Press Enter / Return on your keyboard
  • Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  • Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Change the Save As Type to All Files
  • Type gmapprom.unl in all lower-case letters for the File name
  • Select Save
  • Close the Notepad window
  • Delete the New Text Document file
  • Disconnect the Satnav from your computer
Creating an unlock code file for Mac:
  • Open the TextEdit application located in the Applications folder on the Mac HD
  • Click Format
  • Select Make Plain Text
  • Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  • Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  • Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
4. If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  • Click Explore
  • Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Type gmapprom1.unl in all lower-case letters for the File name
  • Select Save
5. Selecting maps on your Garmin Satnav:
  • Touch the wrench icon on the Where to/View map screen
  • Touch Settings (or Locale on some models)
  • Touch Map
  • Touch Map Info
  • Press the checkbox next to the maps to be selected on the satnav
    A tick will appear in the box. The map is now selected.
Oct 23, 2010 | Garmin nuvi 205W GPS Receiver
When I turn it on it says "Can t Unlock Maps? What does this mean?
The "Can't Unlock Maps" message appears because the unlock code is missing from your satnav. To solve this problem follow the instructions below:
Remove any microSD / SD cards in the device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
After unlocking the maps they may need to be enabled as described below.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Sep 17, 2010 | Garmin GPS
Map lost
The most likely reason is that the map has become unselected.
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
If this doesn't solve the problem the maps may be locked.
To unlock the maps you'll need to register your satnav if you haven't already done so. To register connect your satnav to your computer and go to www.garmin.com Select your country and click MyGarmin. Then click Register Your Garmin Product. You'll have to create a username and password to register. Write them down and keep them safe as you'll need them again anytime you need to update your maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
If you have only one map on your satnav you will need then to select it as described in paragraph 1 above.
If you have a second map on your satnav e.g. if the main map is USA and you have bought a second one of e.g. Europe which also needs to be unlocked;
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
When you have unlocked all maps you will then need to select them as described in Paragraph 1 above.
Aug 10, 2010 | Garmin Nuvi 660 GPS Receiver
I am not able to connect to the google sites from my system. I am able to browse all other sites. What should i do?
If you are using windows xp:-
Click Start, click Run, type %systemroot% \system32\drivers\etc, and then click OK.
  1. Rename the hosts file to hosts.bak.
  2. Create the new default hosts file. To do this, follow these steps:
  3. Right-click an open space in the %WinDir%\system32\drivers\etc folder, point to New, click Text Document, type hosts, and then press ENTER.
  4. Click Yes to confirm that the file name extension will not be txt.
  5. Open the new created hosts file in a text editor, for example, in the Notepad.
  6. Copy the following text to the file:
For Windows XP or Windows Server 2003
# Copyright (c) 1993-1999 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host 127.0.0.1 localhost
Aug 10, 2010 | Computers & Internet
I get the error no detailed maps found that support routing. Hwow Do I fix this?
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The maps on the GPS device have been disabled
  • The GPS device is missing it's unlock code
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device in the botton paragraph
  1. Go to www.garmin.com and log into MyGarmin. If you don't have a MyGarmin account you'll need to register your satnav to get one. To register click on MyGarmin and then on Register your garmin product. Follow the prompts.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 06, 2010 | Garmin nuvi 260W GPS Receiver
Need help setting wordpad for a research paper.
Why don't use "open office" program. its all free. the program is like using Microsoft office which you can format your document easily.
You can download "open office.org from here: http://download.openoffice.org/
note: copy and paste the url to your internet browser address bar.
wordpad is hard to format.
You should format it manually..
may this help,
melnavz
Sep 29, 2008 | Dell Dimension 2400 PC Desktop
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
