Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Mfd2561hes Maytag Refrigerator
For the last 6 months our fridge just goes into a limp mode, of sorts. Reset the computer and it works fine, but then a few weeks later, it does it again. It has power. Now, as of today, every 2 minutes, we are hearing a loud humming noise that lasts for only 6-8 seconds and then shuts off. The freezer and fridge temperature is steadily climbing. But does seem to be cold air coming into the upper fridge and there is a fan running.
  • 1 more comment
  • sureshot123 Feb 15, 2008
    Thanks guys, for your responses. A repairman came out the other day and found that it was our compressor. He first put a new relay on it and it did not fix it. So the total bill for the new compressor and labor was $385.00. The compr is only warrantied for 90 days. He said it could have been caused by surges in our electricity (we have a lot of power outages) or simply a faulty initial installation/compressor. So we have since added a surge suppressor to our circuit (between the fridge and outlet) and we will keep your responses for future reference. From what I understand, the likely hood of this happening again is quite high.
  • LERJR Mar 01, 2008
    Maytag MFD2561HES freezer and ice maker work fine. Refrigerator part is warm. Fan runs correct. Have not heard any strange noise.
  • robert samples May 11, 2010
    take off the back panel and see if the compressor fan is running the humming sounds like the compressor is tripping out on over load overheating be careful around that fan if its not running or something is jamming it un plug the unit before clearing it also let me know what kind of rely box is on the compressor or rather plugged into it esp the color ill be standing by
My Maytag mfc2560hes starting making a noise this am. I checked the fridge and everything is hot. The freezer is still cold, and the items are frozen. What am I to do?
Posted on Mar 29, 2008
Good day..
Replaced Water filter PurClear II for Model MFD 2561 Hew and
button on side of the model refrigerator does not dispense any water when pushed. Help!
Posted on Mar 09, 2008
    President:
  • 1,314 Answers
Glad to be of assistance
Posted on Feb 15, 2008
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Posted on Feb 14, 2008
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
My Maytag Sovereign 60 is tripping the house circuit relay. If we leave if off for a few hours it can be switched on again and runs for about an hour before tripping the relay again. Last happened 2 months...
Could be a problem with defrost heaters when it goes into defrost mode. Also could be problem with wiring to appliance. Try plugging into separate receptacle and see if you have problem.
Sep 06, 2017 | Maytag Sovereign 60 Side by Side...
Have a MFD2561HES refrigerator and both the
i would call who ever replaced your compressor usually they warrant their work for maybe 3 months or so he might have had a bad weld he made when joining tubes,,, it is worth a shot
Jan 31, 2010 | Maytag Refrigerators
Maytag PBF2253HEW; freezer fan not working and fridge not getting any cold air. Ice maker only dropping about every 6 - 8 hrs. What needs to be replaced? (This was a friend's refrigerator, he used for 2...
Mark Remove the rear panel in freezer. Apply 3n1 oil to fan motor shaft and plug in and spin. I believe they left the freezer shut and the moisture froze the shaft on fan with rust. Once restarted you will be fine. Sea Breeze
Jan 27, 2010 | Refrigerators
Maytag fridge stops cooling, then 1-2 days later restarts on own
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
Let us know what you find!
Feb 21, 2018 | Maytag MFD2561HE Bottom Freezer French...
Filtered drinking water freezing in tank
You can cure this problem by ordering part numbers 12002776 and W10130482. Instructions are included with the parts.
Apr 08, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
688 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
