Question about KitchenAid KEBC107 Electric Single Oven
Oven lights Oven light was replaced with a higher wattage bulb than the 1.5. Light worked for a moment and then went out. Light was then changed with correct wattage bulb but the light will not turn on with the switch or when the door opens. Is there a reset button or some other way to reset the system so the lights will work?
    President:
  • 1,314 Answers
I don't know your brand but ive read service bulletins on bad light sockets in ranges id try another bulb first then replace the socket
Posted on Feb 13, 2008
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
The light of the easy bake won't turn on
Take a working lamp and plug it in to the electric outlet you plugged the oven into and make sure it's ok.
There is nothing in the instructions if a light-bulb is used, it does say heating element but there is nothing on how to change anything.
The instructions don't tell you anything but how to use.
If you can return it, do it as fast as you can. If you can't you are going to have to call Hasbro.
1-800-327-8264
So sorry I couldn't be more help.
If you don't get somebody that owns this to respond just post it again, if you don't want to return it and want someone who has it to respond.
Because the door does not open, has no door, the only place I would think of is the bottom might have a access panel.
Have someone see if it has a panel that can be opened and look inside for a bulb and check to see what size and wattage, then make sure you use a appliance oven bulb.
Apr 02, 2013 | Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Correct wattage bulb in Simpson La Scala electric oven.
if you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
May 23, 2011 | Ovens
Replace light bulb
Hello. Unscrew the bad bulb. It unscrews in a counter clockwise fashion. Get a new oven bulb, of the same wattage at home depot or most hardware stores. J.
Jun 26, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Replace oven light
If the metal sleeve that the bulb screws into is damaged, you can go to a local appliance repair shop for a replacement. Be sure to unplug the stove before doing any work on it. you will need the make and model of your oven to make sure you get the right part.
In the future, if the bulb detachs from the base on any light you have, 1) disconnect the power, 2) using a small wooden dowel or the plastic handle of a screwdriver that will fit inside the base, apply enough pressure while turning to remove the base. Good Luck.
Aug 06, 2009 | Ovens
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
KitchenAid KEBC107 Electric Single Oven Logo
250 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
