Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
So i tried the test mode and it started but i stopped it to checv inside and now it wont do anything. all lights are on and no one is home. help please thanks
  • abbygails202 Feb 14, 2008
    back up and running thanks but what does it mean when wash cycle stops and start lite blinks. Will it stop or does it mean a problem
    President:
  • 1,314 Answers
Push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Posted on Feb 13, 2008
  • robert samples Feb 14, 2008
    it means an interupped cycle or too much voltage
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
The green cleaning light won't stop blinking and dishwasher wont start.
something wrong with the panel contacts or the controller is stuck in some unknown condition.
This thread of solution might be helpful.
Mar 27, 2011 | Kenmore Dishwashers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Dishwasher wont work
Press back and forth between the "sani rinse" button and the "heated dry" button several times. This should put it into a "test mode" where all of the buttons light up and the dishwasher does a self-test. Wait about 5 minutes until you're sure the test is complete, and the dishwasher will operate normally. If those 2 buttons don't work, try going back and forth between the "sani rinse" button and the "hi temp wash" button.
Jun 02, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
The start button will not stop blinking.
I hit start and then it started operating in test mode and ran through some tests. I now seems to work fine.
Jan 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
434 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
