Question about Sharp EL-2192Rll Calculator
Register tape How do i feed the register tape thru the calculator?
  • 168 Answers
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Posted on Feb 14, 2008
Calc tape feeds crooked :(
The tape feed path may have to be cleaned.
Mar 19, 2014 | Sharp EL-2630P Calculator
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Jul 17, 2010 | Canon P23-DH Calculator
How do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
Jun 08, 2009 | Sharp EL-1801AII Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Reloading tape roll on a Casio DR-T120
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Feb 01, 2008 | Canon P170-DH Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Casio FR-2650A
the tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Aug 30, 2007 | Sharp CS-2850 Calculator
I'm so stupid
  1. Remove the top gray lid of the calculator
  2. Insert paper through the back side slot near the power charger
  3. Turn the calculator on print
  4. Press FEED a couple times
Feb 26, 2007 | Casio HR-100TEPlus Calculator
Sharp EL-2192Rll Calculator Logo
473 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
