when I insert a tape, the screen flashes "reinsert cassette". So I guess the camera has a problem recognizing the tape. What might be wrong? Reinsert the cassette appears on screen when I close the holder
-   Every time I insert the tape, it loads and flashes "Reinsert the cassette" !!!! I've tried new cassettes... same old readout C:31:23. HELP!!!-   bern2bewild
Jan 16, 2009
-   I've have the same problem with this stupid thing.. I didn't even it a year either. any solutions???-   Guest
Dec 30, 2008
-   I bought a head cleaner tape. It will not "play" in my handycam. I've tried reseting and whacking it. Nothing. I still get the 31:22 message, I think that was the number. If I press reset while the cleaning tape is in, I get a tape is locked message. I will try the recommended tape cleaner later today since I have a standard Radio Shack one now. Hopefully that works because now the pictures are not showing up/playing on my camcorder at all. Before I just had the 5 horizontal gray lines! Now nothing! I don't think I'll be buying a Sony again. I haven't even had this camera a year!-   tiav
Jun 17, 2008
-   Reinsert cassete errors - tried to reset - still not working. Bought casette cleaner - but handycam will not accept the casette. Any other solutions out there? Thanks in advance!-   lewyincs
May 01, 2008
-   reinsert cassette over & over.-   Guest
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
"Re insert the cassette" message is flashing with self diagonosis code"C:31:22"on SONY handycam DCR-TRV285E. When flashing the message( before flashing the code ) just press the RESET buttun and restore the datas.
I lightly bonked the attached battery twice, pushed the reset button under the volume buttons, then I ran the head cleaner cassette 4 times because I have never cleaned the camera's heads. Now it's playing tapes.
dcr-tvr280. Put in cassette and get error message to reinsert cassette. HELP tried resetting button...
(More)
dcr-tvr280. Put in cassette and get error message to reinsert cassette. HELP tried resetting button nothing works
Ater taping, playing or rewinding the tape. An alert of re-insert cassette comes up. If have any...
(More)
Ater taping, playing or rewinding the tape. An alert of re-insert cassette comes up. If have any solutions please let me know how you fixed the problem..
Even after removing the cassette and reinserting it, the message "reinsert cassette" pops...
(More)
Even after removing the cassette and reinserting it, the message "reinsert cassette" pops up on the screen. Repeated removal and reinsertion fails to fix the problem.
My computer stop recognizing when I connect my camcorder.Its a SONY DCR-TRV280. It worked fine...
(More)
My computer stop recognizing when I connect my camcorder.Its a SONY DCR-TRV280. It worked fine before.It has been a few months since I last connected it but it was no problem before.
i have the same problem of reinsert of cassate please send a soluction to me. when i insert the casset and close the door then he display re insert casset.
Comment by Guest, posted on Feb 17, 2008
same dang problem, but it comes with an extra "reattach power supply" command.... i feel lucky when i can actually get the tape out.
so far nothing has helped for more then a few minutes.
