Question about LG CHOCOLATE VX8500 Cellular Phone
End button the end button does not work, i need to take out the battery to turn it off. please what can i do?
    Brigadier General:
  • 7,752 Answers
You need to replaced the keyboard take the phone to a mobile service center and have them replaced it for you.
Posted on Feb 28, 2008
I need to know where the batteries go
Dear Sir: I will help you, please do the following step: Instructions Things You'll Need
  • Power supply
  • Standard screwdriver
  • Batteries
  • Access to local fuse or circuit breakers, if necessary
    • 1 Check to see if the Pro-Form device is properly plugged into a working, grounded power supply if none of the console buttons are working. Turn the device on and reset local fuses or circuit breakers if necessary; reset the circuit breaker switch on the base of the unit.
    • 2 Turn off the fitness device and unplug from the power supply if the console only shows zeros or the console buttons are not working. Use a standard screwdriver to open the battery compartment on the underside of the console. Pull out the old batteries and recycle, if possible. Replace with new batteries, using the old batteries as a guide for the size and type of batteries needed. Place the flat end of each battery against the spring inside the battery compartment and gently push the battery into place. Close the battery compartment and restore power.
    • 3 Press and hold the "Stop" button if the console is only flashing repeatedly, indicating that the device is in demo mode. Insert the console key and push the "Speed Down" button to turn off the demo mode on the unit. Remove the console key.
    • 4 Reset the console buttons if the incline is not working properly on the machine. Insert the console key and press one of the "Incline" buttons. While the incline is in the process of changing, remove the console key. Wait two or three seconds and re-insert the console key.
    • 5 Remove the console key and unplug the Pro-Form device if none of the above steps are resolving the problem with the console keys. Unscrew the three screws that hold the motor hood on the front of the device and pivot the hood off the machine. Find the magnet and small reed switch on the left side of the pulley. Turn the pulley until the magnet is aligned with the reed switch and the gap between the two is approximately 1/8 inch. Reattach the hood, screw into place and turn the treadmill back on
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 16, 2011 | Proform XP Weight Loss 620 Treadmill
The camera does not turn on when I push the on/off button. I tried recharging the battery and it still doesn't work.The button might be stuck in the down position. I am not sure.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 24, 2009 | Canon PowerShot SD880 IS Digital Camera
I have the palm treo pro, I turned it on this morning and the background on my today screen shows but that's all. I can't get anything else to open or move
Hello Mate,
It seems that you phone is frozen and needs a hard reset factory, here is the procedure:
1. unplug the power supply in case it's plugged. 2. open the Battery cover, but don't take out the battery for now. 3. Press and hold the "Power/end" button. 4. While holding this button, remove the battery and put it back immediately. Please don't release the "Power/end" button while doing this operation. 5. Keep pressing the "Power/end" button and when you see "Erase all data" on the screen, you can release the button and then presse "UP" to confirm the reset factory. 6. Continue the setup as if it's a new phone.
Let me know if you need more information.
Best Regards,
Oct 29, 2009 | Palm Treo Pro Smartphone
Samsung Blast Power Button No longer Works.
that happened to me after i dropped it in the toilet. if you pry up the keys around it aswell as the power key because they are all connected and push really hard on the silver thing it will turn on. then just push the keys back in place. trust me it works!
Jul 13, 2009 | Samsung Blast Cellular Phone
Screen is flashing 0.00
I had the same problem with my HP 11C. The following solution worked for me.
1. Remove the battery cover.
2. With the batteries in place (i.e. DO NO REMOVE THEM), use a small piece of wire (I used a standard staple bent at one end), short the terminals FOR A BRIEF MOMENT between both ends of the set of batteries (the HP-11C has three). This means somehow inserting the staple such that the contacts in the batteries receptacle are shorted.
3. The flashing will stop. Then push the ON button until the calculator turns on. If it does not work the first time, remove the batteries and resinsert them.
4. You may have to repeat this procedure. I had to do it twice before my calculator worked again.
Apr 28, 2009 | HP 12c Calculator
End call button doesnt work--need help!!
u have to replace the carbon pad in phone
Feb 13, 2009 | LG Vu CU920 Cellular Phone
How do i reset it?
You may need to reset your Bluetooth devices. Please follow the steps below:
1. Delete BT150 from cell your phone (if listed).
2. Turn your cell phone off completely, and remove battery for 10 seconds. Please consult your phone provider prior to removing battery.
3. Connect the BT150 headset to the charger for 10 seconds, then unplug.
4. Place the battery back into your phone and power your phone on.
5. Remove the headset from the AC cord.
6. Turn off the headset by pressing the answer/end button until the light flashes rapidly, then release.
7. Turn the headset on by pressing the answer/end button until you receive a flashing blue light.
8. Press and hold the answer/end button and the volume plus (+) button until you receive solid blue light. This may take up to 10 seconds.
9. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Oct 09, 2007 | Jabra BT150 Wireless Headset
LG CHOCOLATE VX8500 Cellular Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
