Question about Black & Decker TCM400 Coffee Maker
TCM400 Replace insides of carafe
  • 2,039 Answers
Part #c150-310 go to black and decker webstore to order thanks for using fixya pierre
Posted on Feb 14, 2008
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Thermal carafe clogged
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Jan 03, 2009 | Cuisinart Thermal DGB-600 Grinder
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Need to replace water carafe to Starbucks Barista Araoma 12-Cup Coffee Pot
I have the same problem, but have not been able to find a new carafe, so far.
Jun 10, 2008 | Starbucks Barista Quattro Coffee Maker
Thermos replacement of Pot insides
complete pot part #c150-310 go to black and decker webstore thanks for using fixya pierre
Feb 13, 2008 | Black & Decker TCM400 Coffee Maker
Describe your Black & Decker TCM400 Coffee... Problem:
Here is the manual
http://www.useandcaremanuals.com/pdf/TCM400831.pdf
Nov 20, 2007 | Black & Decker TCM400 Coffee Maker
TCM400 will not perk
Assuming you have power to the receptacle the unit has probably blown the thermal fuse. They are in line with the power to interupt the circuit if the unit gets too hot but over time they will blow out from all the heating cycles. The fuse looks like a small metal cylinder and come in various ratings. You need to replace it with the same rated fuse. They are available at most Electronic parts supply stores.
Dec 17, 2005 | Black & Decker TCM400 Coffee Maker
Black & Decker TCM400 Coffee Maker Logo
108 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
