Question about Black & Decker TCM400 Coffee Maker
Thermos replacement of Pot insides
How to get pot apart to replace insides?
  • 2,039 Answers
Complete pot part #c150-310 go to black and decker webstore thanks for using fixya pierre
Posted on Feb 14, 2008
Replacement of 2.5 crock pot container for three pot warmer
Crock-Pot® 2.5-quart Slow Cooker Replacement Stoneware
www.crock-pot.com/.../replacement...crock-pot-2.5...slow-cooker.../7110025100012....
Rating: 4.2 - ‎19 reviews
http://www.crock-pot.com/parts/replacement-stoneware---crock-pot-2.5-quart-slow-cooker--black/7110025100012.html. 7110025100012 ... Crock-Pot® Hook Up® Connectable Entertaining System 3-Piece Set, Metallic Charcoal. $124.99 ... Replacement Food Container with Lid - Crock-Pot® Lunch Crock® Warmer. $9.99.
Slow Cooker Replacement Parts ' Crock-Pot
https://www.crock-pot.com/parts/ Replacement Food Container with Lid - Crock-Pot® Lunch Crock® Warmer. 4.4 out of 5 stars. Read reviews. $9.99. 20% off Parts Use code: SPARE20. Free Shipping $50+ ...
Replacement Food Container w-Lid - Crock-Pot Lunch Crock Warmer ...
https://www.ebay.com > ... > Small Kitchen Appliances > Cookers & Steamers Rating: 5 - ‎1 review
Replacement Food Container with Lid - Crock-Pot® Lunch Crock® Warmer. ' eBay! ... Free shipping. Replacement Lid - Crock-Pot 5.5-Quart Oval Slow Cooker 129999-000- · Replacement Lid - Crock-Pot 5.5-Qu... ... $16.50. Free shipping. Replacement Stoneware - Crock-Pot 2.5-Quart Slow Cooker- Black 7110025100012.
Dec 10, 2017 | Crock Pots & Slow Cookers
How can I fix my 55 cup Farberware coffee urn FSU 255 model and it won't turn on. Any suggestions? It's always worked well before--this is a new issue.
If it will not perk or even get warm, the main heating element (usually in the middle of the pot) is probably bad. Get an ohm meter and read the resistance directly at the pot terminals (looking into the pot) (before taking the pot apart). If you get a infinite reading (or in the thousands of ohms), the perk heating element is probably bad. On my small pot, that element appears not to be replaceable...but pull the base off and see.
If you pull the base off, you will likely see three components; main perk heating element in the middle of the pot, "keep warm" element - may be covered in braid) skirting the edge of the pot, and finally the thermostat that allows the pot to perk for 7 minutes then opening up the circuit to allow current to both of those elements in series just to keep it warm.
Although I don't have a pot exactly like yours, in my smaller pot, the "keep warm" element (covered in braid) and the thermostat (little button pressed by a spring and screw against the bottom of the pot to sense temperature) can be replaced...go to Goodmans.net.
Jul 23, 2014 | Farberware Coffee Makers & Espresso...
I have had my coffee pot for 3 months, it makes coffee fine, but after awhile i find a whole bunch of leakage on counter. Leaking from coffee container. I took bottom apart and didnt find nothing wrong...
I have a different brand but mine has a thermos inside of the coffee pot itself. The seal at the top kept leaking. Solution was to put some food-safe grease on the seal AND most importantly was putting some on the plastic parts of the screw on the bottom that puts pressure on the bottom of the thermos. The threads gaul and one cannot tighten the screw to put enough pressure on the bottom of the thermos to get a good seal at the top.
Not sure if yours is this type, but if it is this might be a solution to try.
Mar 18, 2011 | Hamilton Beach BrewStation 47224 Coffee...
Replacement inside crock for rival 38601 smart pot 6 quart
crock-pot.com has replacement stoneware crocks for 15.00.
Aug 18, 2009 | Rival 38601 Smart Pot 6-Quart
Coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Jan 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Replacement for liner
Try one of the following sellers:
To contact the manufacturer, try calling 800 #. 1-800-323-9519 (US number) for replacement parts or try www.crockpot.com
Rival Crock Pot Replacement Parts from MarBeck.com
Crock Pot Replacement Parts | Slow Cooker ...
Oct 31, 2008 | Rival 38601 Smart Pot 6-Quart
I need a replacement crock/liner for a model number 3755
Oct 27, 2008 | Rival 38601 Smart Pot 6-Quart
Replacement aluminum pot
I found the pot at http://www.imperialsales.net/ind.html....it's $17 and change. Hope this helps.
Jan 30, 2008 | Hitachi RD4056P 5.6-Cup Rice Cooker
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Black & Decker TCM400 Coffee Maker Logo
144 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
