Question about Brother EM-430 Typewriter
Brother AX430 when i press any letter a different letter comes up
  • Anonymous Mar 06, 2008
    when I type an @ sign i am getting a tiny 2 sign.
    when I type a £ sign i am getting un underlined + sign
    We have tried pressing various shift keys and alt keybut no joy
The solution that worked for me is relatively simple. Close the top flap (where you can access the carriage)...this action will automatically 'turn off' the bale safety switch inside. And then the carriage should 'operate' and type for you! It is a simple 'mistake' that can happen to the best of people...even me.
Posted on Mar 25, 2010
Hi.There, I have a brother AX-430, can you tell me how to switch to bold type, and back again please.
Posted on Jun 22, 2008
  • Brother Master
  • 3,594 Answers
Check to see if you are in proportional spacing, if so move switch to 10 or 12
DickyO
Posted on Feb 23, 2008
  • 398 Answers
This is a common problem. This generally happens when a child plays with the machine or someone thinks they will make the machine work better by cleaning out the carriage compartment.
Inside the carriage compartment (where the ribbon and print wheel are) in the right side of the metal frame there is a small piece of metal (a tab) that sticks out. When you power on the machine the typewriter does something called “Homing.” What this means is, all that dancing that happens when you turn it on is that the sensors are putting everything to a known state. When the carriage goes to the right side the tab hits a switch inside the carriage and that puts the print wheel in Home Position.
Sometimes the tab gets slightly bent which caused print wheel HOME to be incorrectly set. To correct this, the tab needs to be at 90 degrees to the frame. To correct this just power off the machine push the carriage out of the way (to the lest side of the compartment). And slightly bend the tab either towards or away from the keyboard. Then turn on the typewriter test it, it might take a couple of tries.
Normally it’s only very lightly out of square so don’t get carried away. I have ***** seen the tab snapped off but it could happen.
Posted on Mar 10, 2008
How to write smaller letters
Brother typewriters usually come with a Brougham style printwheel. You will need to buy a different printwheel that has a smaller font, like a Prestige Elite. You can call Brother at 877-brother or you may be able to order one from staples or office depot.
Sep 06, 2013 | Brother GX-6750 Typewriter
I am cosidering purchasing a Brother AX430 as it is cheaper than AX100 is there much diference and how old is it. Can you obtain printing and correcting ribbons.
I am not a big fan of Brother T/W's. They have more problems than most and parts are hard to get.
I would suggest a Wheelwriter they are very serviceable, parts ans supplies readily available and they are reasonable.
DickyO
Oct 14, 2011 | Brother EM-430 Typewriter
My brothers typewritter ML 100, when i type a letter it gives me a different letter. if i press k it may give me a b
has someone changed the keys around? compare it to the qwerty keyboard on yr computer and see if the letters are in the same locations to check
May 13, 2011 | Brother ML-100 Typewriter
Quite often (80% of the time) when I receive a fax (letter size) the very bottom is cut off and so I get 2 pages instead of just the one. Doesn't happen all the time but comes from different companies so...
you need to set fax for "auto reduction". press "menu", then "2", "1" and "5". using arrow keys select "on" then press "ok". that should take care of the problem.
good luck,
razors
Jan 07, 2011 | Brother MFC-9840CDW Laser Printer
I'm trying to type on this, but it's not typing the letters I am touching. It types a different letter than I press.
turn machine off for 15 or so seconds and turn back on. if that doesn't work, remove the daisy wheel and inspect the spokes the letters are on. look for bent or broken spokes.
Oct 29, 2009 | Brother SX-4000 Typewriter
I type a letter and a different letter comes out (i.e. i type the letter M and the letter R comes out)
change your daisy cassette wheel, this part is consumable. it is already wornout
Sep 10, 2009 | Brother GX-6750 Typewriter
When we try typing, the letters we press are not what comes out. completely different letters, not sure how to correct.
Check to see if the pitch selection is in PS proportional space. If not the homing pawl spring is probably broken. DickyO
Jun 03, 2009 | Brother ML-100 Typewriter
Different letters despite what I am typing...
look for kb1 and kb 2 or your pitch is selected at ps instead of 10 or 12
May 19, 2008 | Brother GX-6750 Typewriter
Brother EM-430 Typewriter Logo
310 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
