Teac rw-cd22 burning problem
I am coming in on line in rca's ( on a teac rwcd22 cd recorder) and am recieving signal when i select the analog input selector but when i try to hit record the player reads "no cd - da:d2" i have switched the type of cd and am pretty sure that the solution isnt in the cd but something to do with dubbing mode. please help me I am not incompetent with audio equipment and am pretty frustrated as to why this isnt working!!
  • Chad
    Chad Feb 14, 2008
    Yeah like i said it isnt the cd but rather something internal with the dubbing mode
  • Chad
    Chad Feb 14, 2008
    So Like i said im coming in the line in, want to record the music coming in on that line in, I select analog on the input selecter and recieve signal, I go to record and it reads NOCD - DA : D2, I believe the no cd represent the first disc tray but then the second tray, the dubbing tray, is reading DA : D2, this has nothing to do with the CD type, so if you could ponder over my problem again schrody I would appreciate it, also the burner works fine record from the first disc tray to the dubbing tray so Im pretty much at a loss for words as to what the f**k is wrong with this thing.
You were right! I changed the cd and it does not do DA:D2
Posted on Mar 14, 2009
  • djdrewp Nov 30, 2010
    What name brands of audio or music only blank cd's work??? TDK, Memorex, Sony, Verbratim, Pengo don't work... I get DA:D2
    Problem Solver:
  • 17 Answers
Are you using a MUSIC CD-R or CD-RW? You cannot use regualr computer CDR or RW discs in a standalone audio recorder. You must use special blank discs which are specifically designated as for "Music" or "audo". THey have a special code on them that indicates such, and usually cost a bit more than computer discs because an extra tax goes to the recording industry..
Posted on Feb 14, 2008
  • Bruce Stelly
    Bruce Stelly Jun 21, 2011
    Use a Cd-R Music audio by Sony or TDK. push sync all, then it will record your Cd. Unfortunately i am trying to figure out the record input sound because with analog I am good but with digital and coaxial ther is a sound lowering problem.
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
If I had the user manual for this product, I'm sure I could solve it right away. Have every thing connected correctly.By the waym the product is a Teac RW D250 CD/DVD recorder. A question, is it possible...
The TEAC site seems impenetrable as far as just asking for a certain model number but you could give it a try. As a customer you could also complain that it isn't as straightforward as it should be.
http://www.teac.com/consumer_electronics/cd_players_&_recorders/
May 03, 2011 | Teac RW-D250 2-Disc CD Recorder
What disc should i use to burn, on teac rw-cd22 cd recorder
You have to use blank CD-R Audio or CD-R Music CD's in a home CD recorder. It will not record on data disc media but it will play almost any CD with CD Audio music on it.
Mar 10, 2011 | Audio Players & Recorders
Whats the difference between the teac rw-cd22 and rw-d250
I have a Teac RW-CD22 and it keeps telling me there is no TOC> I am unable to record a disc.
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
How do you raise the recording level on a teac rw d200? Im recording into the recorder from another deck and when i playback its so low you can barely hear it
I have the same problem. Are you copying an analog source? (tape?) Even though the "0 db" level is activated, (button on upper right on front panel) the level rises to -12...max. I suspect the auto-level is preset at the factory? Even with an EQ boost there is no level increase. Drives me nuts! Must have to recalibrate it; but I've no idea how...
Sep 12, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
I have a Teac D250 CD recorder it used to use TDK XA80 CD-R discs these are off the market and no other disc seems to work . It displays D-Unclock when I try . Is there a code to unlock this so that I can...
You have to look for input selection and make sure whatever way your recording from is connected. If you doing digital to digital, make sure the optical line is connected and the other is powered on. if it's analog or input or other also the same. I think it needs to recognize the other device. This is info from my teac rw d200. I love this and also use these disc's and maybe they would work on yours. The CD's MUST be made for Audio Burners and I recommend these two kinds...The label below MUST be printed on the CD's in order to work.
8_31_2012_5_05_37_am.jpg8_31_2012_5_06_16_am.jpg8_31_2012_5_06_28_am.jpg8_31_2012_5_22_59_am.jpgthese RW and all purpose are whatever you can find online. The RW just became discontinued. I bought some 2 years ago.
Jun 10, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
945 people viewed this question
 Grubhead
Grubhead
