Question about Bernina Virtuosa 150
Bernina Virtuosa 150 Quilters Edition
I recently had my machine cleaned and the top thread is coming out "grungy"...oily...i'm afraid it was oiled? I have taken the whole machine apart and recleaned it myself...it is a VERY fine silvery substance on the thread so i can't so with white thread at ALL...PLEASE HELP!!
  • 202 Answers
I would start out by putting some cleaner (409) on a q-tip and run it everywhere the thread touches. Guides, tension discs, the under side of the needle plate gets missed alot. Around the hook casing. Then I would just keep sewing on scraps, I know this wastes thread but eventually it will clean itself. A very close zigzag satin stitch would work best.
Posted on Jul 27, 2008
Bernina virtuosa 150
Make sure you are turning the flywheel the correct direction.
Jul 15, 2014 | Bernina Virtuosa 150
Bernina sewing machines
Did you mention this specifically to the repairer? Could be a number of things ..... needle, timing, needle clearance to the hook, burred hook...... all of which should have ben checked when it was serviced. Was there a sample (sewn out by the repairer) with the machine when you picked it up? ie to 'prove' it was working correctly.
Apr 29, 2013 | Bernina Virtuosa 150
Bernina Virtuoso 150 - all of a sudden my machine is dropping stitches and the bobbin thread is bunching up. It also most feels like my machine is trying to do a gather stitch. I changed the needle and...
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Mar 17, 2011 | Bernina Virtuosa 150
My machine is squeaking when using it. Is there an oil hole to put oil into or where is the correct places to oil it?
There is nothing up top to oil on this machine. Don't oil anything up there. Its ok to take the side cover for the needle bar off and oil any two metal parts that move togeather. But just a drop. More can cause you bigger issues when it collects more dirt etc. In my experience when these machines don't get serviced regularily I find squeeking from belt tensioners and hook drive areas. These need to be taken apart and cleaned and oiled or greased. By a Certified Bernina Technician.
Rick
Bernina tech
Jun 24, 2010 | Bernina Virtuosa 150
White thread stitches appear dirty grey
Is this the top thread or your bobbin thread? The technician should have pulled out the tension disk assembly and cleaned it, not just spray more lubricant/cleaner on it. Is this a Bernina certified shop?! Take it back and get him to do it again right, it sounds like carbon/dirt build up in the disks. Have him pull the assembly apart and make sure it's not something else wrong with the disks themselves like oxidization etc.
If it's your bobbin thread.. your bobbin case is just dirty and the spring needs to be cleaned.
The thread doesn't really touch any other parts of the machine, hopefully your technician isn't using grease as this just causes more headaches for attracting more lint and then dirt.
Apr 17, 2009 | Bernina Virtuosa 160
Bernina Virtuosa 153 Quilter's Edition sewing machine jams
Bernina Virtuosa 150 pressure foot does not go down quite all the way. The stitches don't go straight and are not even. PrewettOE
Apr 07, 2009 | Bernina Sewing Machines
Sewing Machines Logo
691 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
