Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
O que faz dar o erro busy na canon? - Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Apr 15, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882353
Points
4663
I can help you fix the BUSY Error of your Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Nao consigo retirar o erro 5b00 da minha mp490, oque fazer?
https://translate.google.com
O erro 5B00 est? se referindo ao contador de tinta. Voc? deve poder redefinir o contador de tinta e continuar usando a impressora como antes, seguindo estas instru??es:
1. Desligue a sua impressora Canon MP490
2. Pressione e segure o bot?o parar / reinicializar
3. Enquanto segura a parada / reinicializa??o, pressione o bot?o liga / desliga na impressora. Isso ligar? e desligar? a impressora novamente
4. Solte o bot?o de parada / reinicializa??o e pressione-o novamente duas (2) vezes seguidas, com movimentos leves, tocando. Por favor, lembre-se de manter o bot?o on / off pressionado enquanto
5. Solte todas as teclas que estava pressionando e espere at? que apare?a o descanso na sua tela
6. Pressione o bot?o de parada / reset novamente por mais cinco (5) vezes consecutivas e, finalmente, pressione o bot?o liga / desliga duas (2) vezes rapidamente
7. Desligue a impressora e ligue-a novamente, e ela dever? funcionar corretamente
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Ola gostaria muito do manual do audi A4 modelo 2000. Pois o que eu achei e em ingles! Tambem gostaria de solucionar um problema no meu audi. Toda vez que piso no freio ele apita, faz um barulho de...
Acho que posso, o que voc? menciona ? o som do "grito" no freio quando o pedal. Poderia ser alguma sujeira na pastilhas de freio or're provavelmente j? passou e est?o se deteriorando outros componentes do sistema.
Sugiro remover os freios e revis?o, tomar vantagem de dar um ambiente limpo e mudar o que precisa ser mudado. Desculpem o texto, mas utilizar um tradutor para isso.
3helpful
2answers
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
28helpful
6answers
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
2answers
Scanner visioneer 4800
go on this site and download it:
http://support.visioneer.com/UK/products/home/EOL/4800/downloads.asp
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
