VOLTAGE REGULATOR WA5236 MOROCCO P6NC6OFP
Can you please tell me of a equivalent part, or the output voltage Input voltage also the current output.
Bush TV Wide Screen WS6674
With Thanks.
4 Suggested Answers
jimbo4026
  • 50 Answers
SOURCE: horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Posted on Nov 28, 2007
ramon49
  • 111 Answers
SOURCE: Do I have Progressive Scan on my TV?
component video is HD of sorts lower end of the scale. Your set has progressive scan..
Posted on Mar 26, 2009
vortash
  • 431 Answers
SOURCE: user manual req
Hi Neil I am vortash .. I find this site prety good for any manuals some are free others reasonably priced it is http://www.safemanuals.com the sites name is diplodocs .com I hope this helps Regards Vortash
Posted on May 15, 2009
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Output transistors
a transistor has 3 leads,[emitter current, collector current, base current, i am going to give you list of options that the transistors can be used for and it depends on the configuration of the circuits.
input resistance, current gain, voltage gain, output resistance, power gain, voltage gain, (input and output power) + [input and output voltage] and {input and output resistance} + input and output power gain.
18 various formulas to a range in groups of 2's
Apr 14, 2014 | Volfenhag ZX-7170 Car Audio Amplifier
I am installinga 4548 inverter. At 4500 watts, it puts out approximately 20 amp per phase. My generater that will feed the charging current for the batteries will put outapproximately 28 amps. Is the...
Let just wait a minute. You have an inverter that is rated at 4500 watts. This spooky. The inverter has a three phase input/three phase output? What is the inverter going to be used for?
Next question. What type of batteries are you using and what is the voltage/current in series or parallel? What will be the total voltage you will producing with the batteries? What is the total current of the batteries.
Another question? What is the voltage of the 28 amps? If it going to dump 28 amps across some batteries that rated at 12 volts and 1400 amp/hrs. For 12 volt batteries with a total of 1400 amps. What you will need approx 14 to 14 1/2 DC and with 28 amps across the batteries for charging these batteries. The batteries will be gone in about 1 hour. Boil all the water out of them. When a battery starts to boil it release water with hydrogen gas (the gas is very explosive and dangerous).
You also don't have a regulation circuit to limit the amount of current depending on the needs of the batteries. Also, you don't have a trickle charger to keep the batteries fully charge when the batteries are idle.
You will also need DC regulated charger that will keep the voltage 2-4 volts above you battery voltage. Without this voltage above the batteries voltage it will not charge those batters. Batteries need to forced to except a charge that why voltage above the source voltage. If you can check the voltage on your car/truck with a 12 volt system. While engine is running the voltage across the battery will be 13.8 to 14.1 volts. Now, the current limiter is the alternator it has a regulator built into it for stabiizing voltage and current went the batteries require more current but it limited by alternator regulator
Now, to get more current out of the alternator the regulator will supply dc voltage to the stator of the alternator generator more current. More dc voltage is supplied by the regulator but the dc voltages is limit to about 24 volts. Another limiting factor is the alternator copper windings diameter---larger diameter more current, small diameter less current. Utilities systems use big mega watts generators. The maxi um dc voltage for these three phase generator would like 500 to 800dc volts for peak to peak output. There is a simpler way of doing this.
You need to rethink everything here. Also, I can help you if you supply the needed information.
I truly wish you luck in your electrical endeavors. GB you. stewbison
Aug 22, 2011 | Refrigerators
I have lost the original power supply for my dell 1701fp monitor. I have a power supply that I think may work as a substitute until I can replace the original. I need to know, what the acceptable voltage...
What ever you use, it must be REGULATED power supply that will maintain 14vdc output, rating at 3A. These regulated power supply can easily maintain the output voltage within +/- 5% with input AC voltage range from 100~240vac.
Linear regulator power supply may not work since it has slow response time to regulate the voltage.
http://www.amazon.com/dp/B002D1E8NE/ref=asc_df_B002D1E8NE1376531?smid=A3IZHOEADOGAP0&tag=dealtmp386264-20&linkCode=asn&creative=395105&creativeASIN=B002D1E8NE
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
How do iknow if my voltage regulator is bad on my 1993 yamaha fzr 600
hi normaly replacing it with another 1 is sometimes the only way to tell, even when tested some electrical items *** up as testing ok, and when you replace them the fault is cured, what is the fault you are getting? is your machine fitted with a seperate voltage regulator, most machines have a regulator rectifier combined, the rectifier converts alternating current ac to direct current dc, where as the regulator controls the amount of voltage, regulator problems overcharging, rectifier problems not charging, and discharging as the rectifier only alows current to travel in 1 direction, when it fails the battery voltage can then travel past it causing a discharging state
Jan 04, 2011 | Yamaha FZR 600 Motorcycles
What output voltage and current is this 04n8984 ibm power suppllay ?
Input Power: AC20~28V; DC16~30V. Output Power: DC12V Regulated. Output Current: 300mA
Jul 27, 2010 | IBM POWER SUPPLY 04N8984 Power Supply
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
Does a laptop charger need a voltage regulator?
No. Your charger is designed to correct for input fluctuations and has a certain tolerances to meet for output voltage and current ripple.
Jun 17, 2009 | Compaq Computers & Internet
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How to test 5v ic regulator(3 pins)
francis, 3 pin voltage regulators have the following;
1 pin is INPUT, let`s say 12 volts
1 pin is OUTPUT, let`s say 5 volts
1 pin is GROUND, all electronics equip. has to have a ground
the problem is they are not all wired internally the same so how do you tell which is input pin and which is output pin ? the best way to find this info is find the data sheet on-line. Google the letters NTE and click on their cross reference link and then enter the number on the front of your regulator and it will cross your device to NTE`s device and show you the info, hope this helps you, Happy Holidays BMW Rider
Dec 01, 2007 | Televison & Video
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
