Question about Panasonic PV-V4523S VHS VCR
Picture flips whill playing tape recorded from cable TV station
Pushing ther tracking buttons does not correct the problem. Panasonic support lead me through a couple of reset proceedures, suggested I buy and use a dry head cleaner and a brand new tape, and switched from channel 4 to channel 3 for watching the tapes but the problem has not been fixed. Suggestions???
  • Oell Feb 24, 2008
    Same problem, picture flips when palying tapes recored on the machine. Tracking adjustement and cleaning does not help.
    Same problem appears when playing tapes taped elsewhere, but stops after short time and pci stabilizes. Problem was not always there
  • Rattelk Mar 23, 2008
    While watching a video, we put it on pause to leave the room for a few moments. When we returned and tried to resume watching, we were only able to see snow, or faint horizontal bars. Sound is fine. Tried dry head cleaner to no avail. What can I do?
  • 979 Answers
All tapes do this, or only ones made on this machine?...accordianman
Posted on Feb 15, 2008
How to tune a vcr
I assume you are talking about the tracking control. Older VCRs had a control that allowed you to make adjustments within a narrow range by turning a knob and newer machines have auto-tracking. The adjustment allows very limited adjustment of electronic centering of the read heads over the recorded video track on the tape. The mechanical and electronic alignment of tape head tracking is a precision process that requires specialized alignment tools and a "standard" pre-recorded test tape. These tapes are very expensive and not as precise as one would hope. In addition, like all magnetic tapes, they stretch and must be replaced. The theory is that if multiple VCRs are aligned on the these standard alignment tapes, all machines will then track and reproduce material alike. Unfortunately, there are so many standard tapes in the world with so much variation that things do not always work well. If you cannot get your machine to play a tape recorded on another machine to track correctly, you could take it to a repair man and have him align it, but it is no guarantee it will track all the time on all tapes. That is why the world has moved on to digital recording.
Jan 11, 2015 | Televison & Video
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
I have copied a personal wedding DVD onto a VHS
I contacted Panasonic direct by phone & they were extremly helpful.
Many thanks ,
Your's, J W Firth
Jan 12, 2010 | Panasonic Televison & Video
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
No sound when playing a tape and wont tune in to the tv stations
No sound on playback is normally the scart lead not fully in either the vcr end or tv
Apr 27, 2009 | Panasonic Televison & Video
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Video Tape picture shakes horizontally
needs tape path alignment or cleaning done
Jan 15, 2008 | Philips DVDR3320 DVD Recorder/VCR
Playback Problems
THE FOLLOWING SOLUTION FROM LABBER (CREDIT TO HIM)
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS LABBER
Nov 13, 2007 | Panasonic NV-DS29B Mini DV Digital...
Panasonic PV-V4523S VHS VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
