Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Rinnai energysaver 1004F
My heater is flashing a number 12, I dont know anything about these heaters, I rent and can not get ahold of my landlord who is not local to me anyway and we are in the middle of a snow storm. Can you help me?
  • aztecapr1 Feb 13, 2008
    the link you provided does not work, I have tried it several times.
My heater is flashing a number 14, I dont know anything about these heaters, I rent and can not get ahold of my landlord who is not local to me anyway and we are in the middle of a snow storm. Can you help me?
Posted on Mar 01, 2008
  • 549 Answers
Sorry friend!
I think this is it.
www.rinnai.us
Posted on Feb 13, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Apr 14, 2008
    code 12 is flame failure, check for obstructions in front of heater. sail switch may not be making up because of not enough air flow or bad switch.
    code 14 is overheat, clean the filter.
I have a paloma tankless water heater (no sure how old) currently renting (landlord useless). Code says C7 12. What is this?
Probably a flame failure code. This is a Rheem product. Go to the Paloma web page and track down the code. Just google it.
Mar 11, 2017 | Water Water Heaters
Water heater using too much electricity.
Check if the TP valve is running water, and replace TP valve. Check if there is water leak somewhere
http://waterheatertimer.org/How-to-replace-TP-valve.html
Replace both thermostats and both elements, and then keep temperature turned down.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Add a comment and describe what you find.
Jun 15, 2013 | Water Heaters
I have to flip the breaker to the water heater to take hot showers
You need to get the landlord to fix that issue. It sounds like an internal short in the heater.
Jul 10, 2012 | Water Heaters
There is a Reliance 640 dort 40 gallon water tank installed in my bedroom closet. It's a mobile home and I rent. It's bad enough that a home model is in there and is larger then a mobile home water tank,...
Water heater explosions are extremely rare.
I do water heater research including insurance data on water heaters >>> the insurance industry has no reports that I've ever seen of exploded water heaters.
The water heater manufacturers experimented on prior generations, so now our water heaters are safe.
You can turn the water heater off when it is not being used.
You can also set the temperature to a modest 120 degrees and then the water never gets hot enough to cause any problem with the TP valve (drain pipe) or any problem burning you when you use hot water.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
If you have a gas water heater, the TP valve will start dribbling water if there is ever a overheating event. So you will see it starting to get bad and then you can report the problem to your landlord
If you have a electric water heater, electric water heater has 3 safety features.
1) The circuit breaker
2) An energy cut-off red reset button located behind the top panel.
3) The TP valve
Here's another solution. Put a metal paint can or metal pot under the TP valve pipe where it comes down to the floor. Do not cap off this pipe.
My last solution is one my friend took when draining his water heater in a rented trailer. He drilled a hole in the floor. Your TP valve should exit the trailer. His solution might not be right for you. But take some photos of the problem and keep them in store in case the landlord refuses to refund the deposit.
Rest well. Every trailer, and every home has a water heater. I worked in the trades for 30 years. I never saw or read of one exploded water heater except the mythbusters video on U-tube (which is entertaining and shows how far a water heater has to be pushed before there is a problem).
Nov 02, 2010 | RELIANCE ELECTRIC WATER HEATER
My wife and I are renting a house. The landlord told us that the water heater was recently replaced. The hot water smells pretty bad. The landlord says that the fowl smell is due to the anode rod in the...
Hi. Your landlord is correct. Anode rod can produce rotten-egg smell. Ask him if he can replace the "sacrificial" anode rod with "Power" anode rod or zinc/aluminum rod to get rid of the smell. However, you need to decide whether you tolerate the bad smell produced by anode rod or the minimal toxin produced by zinc/aluminum rod.
You can also try to drain/clean the tank first then add peroxide treatment and see if the smell goes away. If you do this method, the smell is more likely to come back if you go on vacation and left the heater unused for several days.
This article explains it better: Why Does My Water Smell Like Rotten Eggs (scroll down to page 2)
Let me know if you need further assistance. Thanks.
Jun 18, 2010 | Kitchen Ranges
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
910 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
