Question about Panasonic SA-HE100 Receiver
Dead SA-HE 100
Lightning struck, taking out the receiver, the com adapter in the pc and a phone transformer. I've found 5 fuses on the p/s board, all check ok. I see no sign of a breaker anywhere. No obvious damage or odor. Any ideas?
  • tinroof Feb 14, 2008
    I'm a retired NCR field tech, familiar with schematics and component level troubleshooting, whatever that's worth. A schematic would be most helpful. Anyway, there's no life in the unit. No fan, power cord ok, components show no sign of heat damage, no voltage at transformer. Male AC receptacle (where power cord plugs in)in back of cabinet is a small black box, possibly a fuse(?) Where can I get a schematic?
    Thanks
  • 552 Answers
Most likely if all fuses are good and everything checks out, the something is blown on the circuit board.
In the future it would be best to use a GFCI outlet and a protective power strip, because a power strip for lightning strikes is not fast enough, but the GFCI outlet is and the combination will save sensitive electronics.
I would recommend finding a service man on the website to fix it.
Posted on Feb 13, 2008
  • 4,102 Answers
Hi due to it being lightnig strike their could be that much wrong with it that you might never find the problem.
If you are going to try and repair it then your going to need a multimeter and also get hold of the schematics so you can follow them and for any part numbers you might need.
The chances are its going to be several blown resistors because the lightning strike causing power surge so i would start looking around the board where the power lead goes into the board this would be a good place to start testing
  • paul proctor Feb 13, 2008
    You will need to check any resistors and but the problem could be that it has took out most of the board and you could end up replacing most of the circuitry parts you will need to go through more or less everything but the schematics will help you as following this would give you good idea what it might blow and in what order you can usually get these online in pdf format but getting this would also give you a list of all the part numbers that you might need
  • paul proctor Feb 15, 2008
    So you have checked power is going through power cord this would rule out the plug socket not working if then you have no power to transformer then it must be between the power cord and the transformer the only component you will have between these to point is a fuse it should have on try using a search engine like ask.com
    and type in
    Schematics for then give make and model
    You should find a few sites that have the schematics in pdf format to download if you have trouble locating one let me know and i can look for you ok speak soon
Our landline is dead. We think it was struck last night by lightning. Has 033 342 2034 been struck by lightning?
call the service provider on another phone and ask for the matter to be checked
Apr 12, 2017 | Televison & Video
How do I trouble shoot a tv struck by lightening ?
That is a tricky question, lightning can cause minor to severe damage. If the TV is completely dead, the power supply board will be the first order of things to check, if fuse is open chances are there will be damaged parts and open foil. If fuse blows, board replacement would be the next step, however the risk is will it work, lightning may take 1to 3 boards for example and the unfortuneate thing is you must sub boards until it works.
Mar 11, 2012 | Toshiba Televison & Video
My house was struck by lightning most of all my computers and tv's and phones are no working and my ac is not coming on at all. What happen to my AC unit
Hi and welcome to FixYa, I am Kelly.
The main Preinted circuit board (PCB) most likely has had a failure of the small PCB transformer. This is the most susceptable component (PCB transformer) in the Air Conditioner. Within the last 60 days I have personally experienced the exact same symtom. I replaced the PCB transformer and 1 diode on the main PCB of the air-conditioner and my AC unit is working fine. Unless you can find a source for the transformer your only option is to replace the PCB (Board).
Finding the exact transrformer for the PCB can take a very long time. It iwll look similar to this one: http://www.machsources.com/productimages/9913/pcb-mounting-transformer.jpg
If you have home owners insurance ALL STATE and State Farm often cover this type of damage. It is worth the time to find out if you are a home owner.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Frigidaire FAC085M7A Air Conditioner
A couple of days ago lightning struck really close to my house and now my tv doesn't work. I've opened the panel on the back hoping that since it was struck by lightning that it just got...
At least look at the main AC fuse (F1) in the power supply module, and also look to see if any of the MOV's has blown.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jul 03, 2011 | Sanyo DP26648-R 26 in. LCD TV
My tv won't power on after lightning struck and made the power flicker. i've tried unplugging it and leaving it unplugged for several minutes with no luck. is there a fuse?
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Jun 28, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My 47LG50 is just over 2 years old, about 30 days ago I started to lose the video/picture At first it happeded every once in a while, now it is every 5-8 minutes. I can turn it off and turn back on and it...
This problems it could be those 2 long LCD inverter boards are dead,so it is not giving ur tv LCD screen panel the backlight to produce a picture or the tv Tuner signal board itself is the problems it dead.That the board,that take in the incomming broadcasting signal wire ur case the HDMI or Component cables.Take out the incomming broadcasting signal to the tv,turn on the tv,now tv have no picture,it should have a loud white static picture noises for good more 5-8 mins,than problems it not the tv Tuner signal board.Than it is those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes 2 long inverter boards or the tv Tuner signal board for the replacement.
Mar 25, 2011 | LG 47LG50 47 in. LCD HDTV
Tv struck by lightning and will not turn on. Can it be repaired or is it a lost cause?
Yes,it repairable.The tv have power at all like the LED power light indication flashes?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.No power LED light indication all.The power supply board is dead and also the Tuner signal board is dead.Must replaced both boards.
Oct 16, 2010 | Polaroid FLM-3232 Television
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 08, 2010 | Insignia NS-LCD22-09 LCD HDTV
Nothing works.
Remote receiver got fried by the voltage spike. If you have pull chain controls as well, you can remove the receiver and possibly be able to save the fan, but the capacitors, may have also been fried. If the capacitors are fried, then most likely the motor experienced some seriously high voltage too, which would mean I would replace the fan. I assume you have had the house's wiring inspected? If lightning struck the house and killed the fan, then it likely ALSO damaged other electrical components. If the lightning struck your power transformer and not your home directly, you may can get the power company to pay for this ceiling fan as the transformer is supposed to have a lightning arrester on it.
Mar 31, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Struck by lightning and won't power up
WOW!
Warranty voider there.
Hate to see a $1,000 TV go down the toilet.
If your lucky, you can try checking the fuses inside the TV.
The lightning may have taking out only your power supply board, shopjimmy.com may have replacements for about $100. But, I can't tell you for sure that will fix the problem.
You may have to take to a repair shop to find out for sure.
Good Luck
Feb 11, 2009 | Philips 47PFL3603D LCD TV
Panasonic SA-HE100 Receiver Logo
162 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
