Question about Texas Instruments TI-84 Plus Calculator
PRGM A I recently installed some games and ions on my ti-84 plus calculator. the games saved into the program a folder, but then when i was playing, my calculator crashed :P i had to remove the batteries and that cleared the memory, including the program a folder. will the games be able to work again if i install the ions and games? or how do i get the program a back?
    Problem Solver:
  • 5 Answers
You should go to ticalc.com to get the latest os for your calculator.
assuming that you have the usb link cable. Or just go to the texas instrument site and install the graphlink sofware ant it should check for any update for your calculator by it self.
Posted on Mar 04, 2008
TI-84 ALPHA + F1 does not work!!! it used to, but now it doesn't, can I know how or why it happened?
I had a similar problem on my TI-84 CSE. I solved it by resetting the RAM (2ND, MEM ('+'), Reset..., All RAM, Reset).
If you have programs on your calculator you don't want to delete, you can move them to the "archive" memory first by 2ND, MEM, Mem Management/Delete..., Prgm, and then pressing ENTER next to every entry that does not have a * next to it. Go back and select them again after resetting the RAM.
You said this problem was the result of it working at one point, but then not working anymore. If someone does encounter this problem on a TI graphing calculator where it never worked in the first place, you need to install an OS update from the TI website.
Jun 14, 2014 | Texas Instruments TI-84 Plus Silver...
Entering in missing data on saved program
Press PRGM. Select EDIT, then the program to be edited. Move to the line before which you want the new line inserted. Press 2nd [INS] ENTER to insert a blank line. Type in the missing line.
Exit the editor when done. The saving is done automatically.
Mar 06, 2012 | Texas Instruments TI-84 Plus Calculator
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Installing new OS
Hi mcniester,
If you need to install Ti Connect software, goto the paragraph (1) below. If you do not need to install Ti Connect software goto the paragraph (2), "Procedure to installing the newest Ti 84 Plus OS 2.35v."
1). You can get the latest copy of Ti Connect software by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti Connect software" At this Ti site under "View: Connectivity Software", Click, "the OS link that applies to your computers operating system". Next, click the Download Item, "Ti Connect software for ....OS". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti Connect software for ....OS will be download to you. Click, "OPEN" and the software will start installing. You will have to click "Next" a few times but, it install pretty fast. Once the Ti connect software has successfully installed follow the instructions to the
"Procedure to installing the newest Ti 84 Plus OS 2.35v." below.
2). You can also get the latest copy of Ti84 Plus 2.35v OS and guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.35v. OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system download to you. Click "SAVE" And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and calculator with the USB cable or Direct Black Link cable that came with the calculator. Next, drag the Ti 84 Plus OS 2.35v that you copied to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti connect" icon on the desktop. Click, "Continue" and, the new Ti 84 Plus OS 2.35v will begin to install. The Ti Device window may pop up and, click on to the port your Ti 84 Plus is using, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 84 Plus OS 2.35v will be installed.
Jan 06, 2011 | Texas Instruments TI-84 Plus Calculator
Protect program
If you can upload it to the computer, you can open it with prgm editers, and they should have a selection for protecting the prgm. The editer i used was TI-program editer, unfortunately, new windows updates made that program impossible to use on Windows XP and TI didn't update it or anything so yeah...I don't know about vista though, you can try that. Another way is to open the file through Mirage OS and 'lock' the program. To make basic prgms visible in mirage, simply put a : at the very first line. The problem with this method is that anyone with Mirage can unlock it and change it...
Mar 25, 2009 | Texas Instruments TI-84 Plus Silver...
Is there a way to play games and put in a password on a TI-83 plus?
Yes, there is. There is a program called mirage os and another one but i forgot the name. You should google it to find online. You need to have ti connect which you can get it off the ti website. Well mirage os can have a password by pressing alpha in it. Also in order to have a password to turn it on you would need to go to mirage and then press on and then it should turn off. To program you would need to know assembly or ti basic (they are basically the same language). To start programming he would need to press the prgm button and the options are reached by pressing the prgm button again.
Sep 10, 2008 | Texas Instruments TI-83 Plus Calculator
Save something in my calculator.
go to programs and hit new. name your program and then you can type away. This is where you can actually program programs such as as program that will do the Quadratic Program and stuff like that but that's more complicated. But now to look at that stuff hit prgm. and then edit and you can look at what you want to see. GOOD LUCK hope this helps
Jan 16, 2008 | Texas Instruments TI-84 Plus Silver...
Cant play games on calc
This probably is not a problem with your calculator. A syntax error is caused by the program you are running. It just means that the game you have downloaded has a bug in the code and is unplayable. Check out TiCalc.org for a lot of working games and programs.
Aug 27, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
154 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
