Question about RCA RS2664 Shelf System
Radio won't stay on station
The radiu drifts of the station. Can I fix that myself? If so, how? Where is the nearest RCA Service Center to Daytona Beach, FL
  • Christina Abfall May 11, 2010
    can you fix the radio drift?
How long does it take for a letter to go from daytona beach, fl to seattle, washington
2-4 days. All depends on how it's mailed. Overnight would be there the next day. But it'll cost you bucks
Oct 03, 2014 | Home
Does anyone know where the aerial / antenna is for a Mercedes R320 R Class 2006
I would be asking the service dealer centre this question because some upper priced cars have the aerial in either the windscreen glass or the rear window glass. some aerials are nothing more than a small fiberglass bump on the hood near the rear . Instead of taking the wireless out for repair that is not fixing the problem , take the car to the shop and have the technicians check it in car for a problem
Apr 25, 2014 | 2006 Mercedes-Benz R-Class
Dog ate remote where can i find one?
Hello
If you want to get its original model remote control; you have to contact the nearest RCA authorised service center at your town. You can't buy its orignal from nowhere else. A universal RCA remote control will work with it, but sometimes some buttons of it may not synchronised. So try to get its original model. Moreover, if by anyway this set happened to be in FPA lock, you cannot open the lock without the orignal remote control. A universal remote control, whatever it may be, won't work then. OK.
Sep 24, 2011 | RCA 20F512T 20" TV
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
Need gasket at spray gun handle for tti lx-80
You can get them at a paint store or you can make one i have serveral LX80s and i rebuld them all the time . If you have a build up of paint clean it with laquior thinner its a simple seal and it never wares out Ihave these guns that are 20 years old and the olny time i ever had a problem with this seal was when i used a torch to clean the gun before rebuilding it So keep it clean and you could use it every day and rebuild it every 5 years
Apr 05, 2011 | Titan Air Tools & Compressors
Thankyou for assisting me . On my Daytona , the top and bottom press buttons wont work the stop watch second hand at all. Also they must be screwed out to allow them to be pressed in . Is that normal ?
I don't know the solution to your problem (your could always send it to their nearest service center; see Rolex.com) but screwing out buttons is a feature that is often included to give maximum water resistance.
Feb 10, 2011 | Rolex Daytona 116520 Wrist Watch
RCA RS2664 Shelf System Logo
80 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
