Question about KitchenAid KESC307 Electric Kitchen Range
Our oven door accidently locked. How can I open it?
It is a Tappan. Model no. TEF355BFWA
Serial no. VF74418035
  • ooger Feb 14, 2008
    Thank you for your suggestion. It didn't do the trick but a friend came, punched at random and yes it opened. But.......when I try to operate other features, dr pops up.
    We kept a cloth between the stove and oven so it wouldn't lock again. Top burners work and the lite by lock button still flashing. But praise the Lord it isn't locked.
    Looks li8ke I just might get a new one. Thanks again. hn
    President:
  • 1,314 Answers
Try pushing clean then cancel after about 30 seconds
Posted on Feb 13, 2008
  • 1 more comment
  • robert samples Feb 13, 2008
    push clean start then cancel
  • robert samples Feb 14, 2008
    if you pull the range out and remove the back panel you will see a little motor with a rod and one or two micro switches on it if one of thoose micro switches is bad or something is between it and the acuator cam will cause this promblem
    This failure will only apply to
    ranges that have two switches in the monitor circuit of the latch motor assembly. These
    switches will be labeled Lock Switch A and Lock Switch B on the wiring diagram. On the
    lock motor assembly switch A is the lower switch and switch B is the upper switch. The EOC
    constantly monitors the condition (open or closed) of the microswitches and if the switch
    contacts fail either open when they should be closed or vice versa, then the EOC will run
    the lock motor to try to correct the condition. This will sometimes also result in a fault code
    displayed on the EOC.2
    Internal short in oven door light switch.
    This is the most frequent cause of the intermittent
    nuisance locking of the oven door. On many models the oven light switch has two
    independent electrical circuits. One set of contacts serves as an interrupt circuit to the
    latch motor to prevent the motor from running if the door is open. The other set of contacts
    supplies line voltage to the oven lamp or oven lamp relay when the door is open.
    There is a specific type of short circuit that can occur inside the body of the switch which
    allows the voltage that would normally be supplied to the oven light circuit to bleed
    through to the latch motor contacts and cause the motor to run. This failure is difficult to
    diagnose unless you are present at the time of failure. There is one technique that can be
    used to achieve an accurate diagnosis when this failure is suspected. Locate the wire on
    the E4 or MDL terminal of the EOC this is usually a pink wire that comes from the oven
    door light switch. Disconnect the wire and insulate the terminal with electrical tape.
    Secure the wire so that it can not touch any other electrical components or short to
    ground. With this wire disconnected and secured allow the customer to continue using the
    range to see if the nuisance locking occurs again. If it does then there is no doubt that the
    cause is an internal short in the body of the oven door light switch.
    Problem:
    Cause:
    Solution:
Where is model number on tappan range about 25 years old
Good Afternoon Esmond, this is Z. I am happy to assist you!
The serial tag of your range, which lists your model number, may be found in the storage drawer, on the right side or on the front of the oven, in the upper left corner, as you open the door. I hope this information proves useful.
Mar 01, 2014 | Tappan Kitchen Ranges
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
Oven door
replaced oven igniter without removing oven door
Jan 08, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan gas oven dooor won't unlock
We were able to solve the problem by accident. As I think I mentioned the door must of locked when we were cleaning the control panel. Anyway the door locked and the burners would not ignite.The door was open so you were not able to shut it to try and clear it. I searched the owners manual, there were no solutions as to how to reset the Range. I even checked the manufacture's web site. I got down to inspect the door and ran my hand along the inside edge of the oven and there was a button on a spring. I pushed on it and there was a hum and the latch opened and the Range must have reset. It's working perfect now.
Dec 07, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Door Lock Light Flashing
If you live in Huntington Beach, CA and need appliance repair service call us at (714) 698 88 73 or visit our website Appliance Repair Huntington Beach CA 714 698 88 73
Aug 30, 2017 | Tappan TGF320 Gas Kitchen Range
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
what do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Feb 13, 2008 | KitchenAid KESC307 Electric Kitchen Range
Tappan electric range door locked
Check the door lock switch/solenoids. You'll have to unplug the range/stove. Remove the solenoid and check to see if it has continuity or if the solenoids are stuck.
You also might have luck resetting the clean cycle. Even though the lock is engaged, try to open the oven door a little. Start the clean cycle, then cancel it.
Dec 13, 2007 | Kitchen Ranges
KitchenAid KESC307 Electric Kitchen Range Logo
129 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
