Question about ASUS P4P800 SE (890552603657) Motherboard
Cannot see 4 gb ram
Hi guys, I have 4 times 1gb ram but the bios only see 3Gb and the system boots very slow. Is there anything I have to set in the bios?
Francesco
  • ohiotom May 11, 2010
    I don't believe there is any setting in the BIOS.
    Have you tried pulling out all but one module and booting? If it's still slow trying booting with just one other module. If it seems to boot faster then try adding a 2nd module and so on...
    Problem Solver:
  • 6 Answers
Hi Ciccio8670,
If you are running 32-bit Windows, you must live with it. You will not ever see all 4GB of RAM you've paid for.
If you are running 64-bit Windows, you may have to live with it. Depending on your motherboard's chipset, your system may support memory remapping. If so, you will be able to use all 4GB of RAM.
Detailed:
Due to an architectural decision made long ago, if you have 4GB of physical RAM installed, Windows is only able to report a portion of the physical 4GB of RAM (ranges from ~2.75GB to 3.5GB depending on the devices installed, motherboard's chipset & BIOS). This behavior is due to "memory mapped IO reservations". Those reservations overlay the physical address space and mask out those physical addresses so that they cannot be used for working memory. This is independent of the OS running on the machine. Significant chunks of address space below 4GB (the highest address accessible via 32-bit) get reserved for use by system hardware: • BIOS – including ACPI and legacy video support • PCI bus including bridges etc. • PCI Express support will reserve at least 256MB, up to 768MB depending on graphics card installed memory
What this means is a typical system may see between ~256MB and 1GB of address space below 4GB reserved for hardware use that the OS cannot access. Intel chipset specs are pretty good at explaining what address ranges gets reserved by default and in some cases call out that 1.5GB is always reserved and thus inaccessible to Windows.
Posted on Feb 13, 2008
  • dokto205
    dokto205 Jan 20, 2012
    I disagree... If bios don't recognize 4 gb of ram in the starting of computer time its not be changed when you install 64 windows... but if bios recognize whole ram and windows not the problem is in the os...
BIOS says 3GB RAM, Properties says 2GB RAM
You may want to flash your bios on the motherboard if there is an update. Windows XP Pro will support up to 4GB of RAM.
Feb 20, 2013 | Microsoft Windows XP Professional
2*2GB (4GB) ddr2 shows up as 2*1GB ddr2 (2GB)
It could be a problem if you are running a 32 bit operating system. I know that there is a limit of around 2gb on any 32bit windows install. this can be fixed by installing a 64bit version, IF your hardware supports it. You would need a 64bit cpu to install 64bit windows. If this is not the reason you are having the problem, the only other reason that would make sense would be that your motherboard doesnt support more than 1gb of ram per DIMM hence it shows that two are insalled but can only use one gb each. This i think is the more logical answer because I think the limit on GB for win 32bit was more like 3gb. good luck
Oct 08, 2012 | Intel DG43NB Motherboard
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
Hi I got some new SDRAM cards and put all of them
Each pair of ram stick go in the same color slot (2 x 1 GB in green for example) then the 2 x 512MB go in the other slots (may be pink)
you also need to make sure that your motherboard supports more than 2GB
Mar 25, 2009 | Computers & Internet
OS not showing full RAM
Hi Shibbymusic, as with most Asus boards if not all! The MB
A8N-E does not show all of your 4GB memory. See this FAQ;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=A8N-E&os=17
Like you, I too have 4GB of memory.
Asus A8N32-SLI Deluxe w/4GB memory only see's 3GB
The bios displays 3GB during boot up & so does windows XP 32bit.
You might want to think about upgrading to 64bit os.
Updating your bios should help as well.
(See A8N-E Bios version 1010); http://support.asus.com/download/download.aspx?modelname=A8N-E&SLanguage=en-us
Thank you for using fixya!
Mike
Dec 07, 2008 | ASUS A8N-E Motherboard
More ram and vdeo card
it sounds as if your MoBo is seeing the video adapter as a source of ram. if that is the case, then installing memory in units of 1Gb will cause a stick to not be seen, therefore utilized. you may want to refer to you manual for memory limits and poosible comparibility issues. they are usually quite in depth. also, make sure that they are all the same make model and speed. these issues have wreaked havoc on the prettiest of pc's.
Nov 28, 2008 | Computers & Internet
4gb on msi k8n neo-4 F
Hello pejegess,
If your OS is reading the 4Gb, it will be running the 4GB even if the bios is only seeing 3GB. You may just need to update the firmware on your motherboard but I suggest that you just leave it as is since the OS is recognizing the 4GB.
Sincerely,
Agent Xiong
Jun 03, 2008 | MSI K8N Neo4-F Motherboard
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspireā„¢ T180 PC Desktop
ASUS P4P800 SE (890552603657) Motherboard Logo
366 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
