Question about Mitsubishi VS-60805 60" Rear Projection Television
Make TV go to 1080p
My TV can only change to 480p or 960i but says on the Tv that it is 1080HD series
  • 3 more comments
  • fritolay55 Feb 20, 2008
    It is hooked right and nothing happens. Thanks anyway.
    I tried all what you said and it was already hooked up that way and it still only gets 480p&960i. Thanks anyway.
  • fritolay55 Feb 21, 2008
    Thanks alot, but I still have one question. What is better 480p or 960i when it comes to the quality of the picture. Again thank you.
    Thanks.
  • Anonymous Mar 28, 2014
    How can I auto scan for channels on my tv?
    Sergeant:
  • 395 Answers
The set has two sets of componet (Y,Pb,Pr) inputs one can only except the 480p the other can get the 1080i. this one is labled DTV on the back. first you must go into the menu setting to "set up" then to "assign input" then "DTV" to "Y,Pb,Pr". make sure you connect the cables to the DTV connection in the back. you will not need the H and V connections that is for RGBHV connections.
Posted on Feb 20, 2008
  • 1 more comment
  • Robert Johnson Feb 21, 2008
    If you are trying to do 1080p the set can not support 1080p, 1080i only. 1080p is unsupported by this set. 1080p equates to 2160i this set can not scan that high. this set was made before 1080p was ever thought of.
    if you look to the upper left hand corner when changing the input it will display the incoming signal as 480i,480p, or HD16:9 which is the 1080i incoming signal. your set automaticly detects the HD signal and will switch between the SD and HD when the signal is present.how do I know this? I have the 805 series. and repair them as well. since your set is a 4:3 aspect when you are recieving HD the picture changes to 16:9 leaving black bars at the top and bottom of the screen that you can not change. on page 52 of the manual, if you are trying to change the video display of the screen, 480p is the default setting of the up conversion of 480i it reads as follows.
    Your Mitsubishi television
    automatically doubles the
    lines of the standard 480i
    (interlaced) pictures. This
    provides a smoother, more
    film like image.
    The default doubling is 480p
    (progressive). If you prefer,
    you can choose to display the
    picture as 960i (interlaced).
    the differance between progresive and interlacing is in interlacing there are 2 fields per frame. half the lines(odd number) go on the screen first then the second half (even number) go on to "paint" the frame. there are 30 frames "painted" per second.
    in progresive scan all the lines go on to "paint" the frame again 30 frames per second.
    altho your eyes put these frames together to make motion if you were to slow the frames down some fields in interlacing would appear as double image. so interlace can appear gittery. that is why in the old 480i sets if a straite line appaered on the srceen it appears to jump up and down. but as for 960i the scan is so fast you can't see this gitter. I personaly set mine to 480P but I rarely use that setting because I'm mostly using the HD input from directv.
    Sergeant:
    Champion:
  • 301 Answers
Make sure that you have your HD source hooked up to the correct input on the tv. you are going to want DTV as the input.
I have a sharp TV and an trying to CD an Amazon fire stick. TV keeps responding...incomparable video signal...help
The stick is set to 1080p your sharp tv cannot show 1080p change it to 480p in settings , you will have to use it in another tv than is capable of showing 1080p, then just change it to 480p , then you should be able to use it on the sharp tv. You can then try to change it to 720p if it says the same about the signal leave it for 30 seconds and it will revert back to 480p
Aug 02, 2017 | Sharp Televison & Video
How do i change from 480p to 1080p on my rca remote
You don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV reports the resolution of the incoming signal before it is scaled. If you have a BD player you can see the effect of changing the resolution setting from 480p, to 720p, to 1080i, to 1080p 60, to 1080p 24. The last three (the 1080 resolutions) shouldn't look too different with a Blu-ray apart from movement because the native picture is 1080p 24 and the TV is simply converting it back to 1080p 24 for display.
Sep 07, 2014 | RCA D52W23 52" HDTV CRT TV
Panasonic th 46pz80u
Yo don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV is a fixed pixel device. The panel has a resolution of 1920x1080 pixels. The incoming video signal is scaled to fit that display. If the signal is 480i then it is deinterlaced to make it 480p, and then scaled up to make it 1080p. The amount of detail in the picture doesn't change. It's still a 480i image. It's just blown up to fill a 1080 panel.
960i is a funny resolution. That would be achieved by line doubling a 480i signal. But it's not one of the VESA HDTV timings. TTBOMK there's no Blu-ray or HD source that generates a 960i image. So even if you could generate it then the TV wouldn't understand what to do with it.
Aug 25, 2014 | Televison & Video
TV was getting 1080p resolution Now 480p
Look in your menu for the resolution setting and change it back to 1080
Aug 14, 2014 | Toshiba 32L2400U 32" Class 1080p LED TV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 31, 2011 | Televison & Video
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Mar 30, 2010 | Televison & Video
Cant get 1080i
This TV came out in 1999 and the HDTV standards wern't established yet. Just make sure you are using the DTV YpRpb inputs and not the DVD YpRpb inputs on the back of the set. Leave the menu setting at 480p and on the :"ASSIGN INPUT" sub menu make sure "DTV" is set to YpRpb. Even then it may not be compatible with a PS3 at 1080i.
Sep 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
330 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
