Question about Panasonic KX TGA400B Cordless Expansion Handset
Handset We have this 4 line phone for our home office and have replaced one handset because the #1 key/button would not work. Is there any way to repair this without having to spend over $100 for another new handset? The other numbers work just fine.
  • 1 more comment
  • koke794 Jan 13, 2009
    I have a similar problem. I took it apart, cleaned the pad but when I put it back together, I noticed the battery getting very warm and the battery icon only shows 1 bar. Can anyone help me to troubleshoot this?
  • davidcbaker Jan 28, 2009
    I have the same problem after cleaning my keypad. Reassembled the unit and now the battery shows one bar, it heats up in the charger, light works on the phone but none of the buttons respond.
    Anyone know what this problem is?
    The manual states that this problem (one bar on battery after charging) means the battery needs to be replaced. Weird that the battery was working fine (talk time, standby time) befoe I took the thing apart.
I have had this problem multiple times. It is apparently a flaw with the keypad on the phone. The keypad emits too much oil and causes it to stop working. I've sent my phone in twice to get the keypad replaced (there are companies selling replacement pads on ebay), otherwise, I've just learned to take my phone apart, wipe off the contacts and it works fine.
Posted on Apr 22, 2008
    Novelist:
  • 106 Answers
Yes that is a common problem, and you can send your handsets in for repair with a number of options. There is Panasonic in McClellan Texas that is of course the most expensive, and I believe they exchange your handset with another. Then there are independent facilities that are less expensive and sometimes better, where you normally get back the handset you send in but repaired/refurbished, etc. But you do get what you pay for, just like everything else. You can do a google search for "Panasonic Cordless Telephone Repair" and go from there. There are repair deals for full refurbishing, new plastic, new batteries all included to fully freshen up your phone if it needs more than the buttons fixed, you merely need to ask if you think you want to go that route. Good Luck, CG
Posted on Feb 14, 2008
My Droid x hd is frozen and I can't get a response
Remove the backing of the phone and pull out the battery. Then put the battery back in and turn on the phone. If remove the battery isnt an option,
1. Turn off phone
2. Press and hold Power key + Home hard key to power on the phone and bring up a triangle with an exclamation point inside next to a green Android graphic.
3. Press Search hard key (only froyo 2.2) to show the Android recovery menu. ( for firmware 2.3 Gingerbread Press both Volume buttons)
4. Tap to select "wipe data/factory reset" (you can also use Volume buttons to scroll up or down in this menu)
5. Press Menu hard key under "Ok" screen prompt (camera button can also be used to confirm selection)
6. Handset will ask you to "Confirm wipe of all user data"
7. Select "Yes -- delete all user data"
8. Press Menu hard key under "Ok" screen prompt to start wipeout of phone, handset will begin to format handset showing progress with multiple lines of ellipses (....) (camera button can also be used to confirm selection)
9. Handset may take from 5-20 minutes to format.
10. When format is complete, press Menu hard key under "Ok" screen (or use the camera button) when prompted to reboot (Reboot system now will be highlighted)
11. You will see either an open box and the green android graphic when handset is rebooting (or the red DROID eye graphic).
12. Handset will be cleared of previous personal data, and you will need to start over with initial set-up process.
Sadly thats the only process which includes wiping contacts etc. and last alternative.
Oct 20, 2013 | Cell Phones
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Troubleshooting droid
1. Turn off phone
Portable hand set will not hold charge longer than 10 minutes.
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps are worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Mar 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
Phone getting switched off when speaker is turned on
(Just received this from Panasonic Support...Thanks Panasonic!) The following might be worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Dec 21, 2008 | Panasonic KX-TG4321B Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
RE: NEC DTP-2DT 2 Line Digital Phone HandSet
i believe the nec dtp-2dt maybe a phone system phone for offices. you didn't mention if it's for home or office use.a phone system phone will not work in a regular phone jack. it needs to go thru a phone system. also if you buy any 2 line phones, you need 2 lines for both lines to work. you can also have a 2 line phone with only 1 line and order a 2nd line if needed
hope this helps
wg
Jan 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Vtech M6896 phones do not work
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
Jan 18, 2008 | Vtech mi6896 Trio Cordless Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Cordless Handset fails to Link to main corded phone
Here it is, 2008, March and still no answer! LOL! I am having the same problem! It linked fine when I first got it, and now since I can't find the manual I can't get it to link again! Can anyone help? Please
Apr 13, 2007 | GE 27957GE1 Phone
Panasonic KX TGA400B Cordless Expansion Handset Logo
224 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
