Question about Canon PIXMA MP780 All-In-One InkJet Printer
Cartridge My printer is not working as it tells me to put in cartridge. All ink cartridges are in and I have removed and replaced several times. WHAT NEXT?
Your printer is actually complaining about the print head and not the individual ink cartridges. There is a known problem with the cartridge clogging up and overheating when many CDs are printed.
First try to remove and reseat the actual print head: remove the ink cartridges first, then pull up the grey lever and take out the print head. Check for visual damage and/or clean but be careful with this.
Reseat the cartridge, put the ink tanks back in.
If this does not result in a working printer, order a new printhead from your local supplier.
Posted on Feb 14, 2008
Remove and check cartridge on right. I have removed it several times but still comes up with message and will not work
All I did was replace my black ink cartridge with a new one and it works. You think it would say replace ink cartridge instead of remove and check cartridge on right. Good Luck.
Aug 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My SX600FW Epson Stylus will not print black even with new toners?
We took ours to a local repairer who used a special program to blast the heads. We had tried head cleaning ourselves and this didnt work. It has had to go back two or three times but it does work for several week after.
May 05, 2010 | Epson Stylus CX6000 All-In-One InkJet...
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
Full cartridges = empty :S
Solution 1
* Remove the tank.
* Connect a hose directly on the inlet ink.
* Locate the sensor of reservoir and press it to make as if a cartridge is available.
* Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
* Replace the tank up and do a test print.
* Repeat the procedure several times if the nozzles are clogged.
Solution 2
* Step 1: Remove the cartridge from the computer
* Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
* Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
* Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
* Step 5: Run some test prints before using the printer normally.
Jan 02, 2010 | Epson Stylus 880 InkJet Color Printer
Printer will not work after installing a new ink cartridge?
did you see a piece of plastic stuck on the back of your cartridge?
Mar 21, 2009 | Lexmark C533DN InkJet Printer
Replaced black ink cartridge and it says its low
Some newer printers, such as Lexmark, will have a place in the properties app that allow you to "tell" the printer the cartridge is new. Check yours and see, it fixed mine.
Jan 04, 2009 | Dell 922 All-In-One InkJet Printer
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Ink tank
Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
  • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
